At long last, I'm starting to assemble a mountain of bits and pieces, made over far too many years, into a 2" scale 'Minnie' traction engine.
The boiler has an external, raised, 1/8" copper thickening plate (unmachined after being silver soldered to the boiler barrel) for the mounting of the cylinder and I would welcome views on the best way of sealing the joint between the pad and the machined curved surface of the underside of the cylinder.
At present, I am thinking of the following 'sandwich' :-
- Coat boiler pad with Foliac jointing compound.
- Fit 1/32" Reinz AFM30 gasket (widely used for steam joints and already made).
- Coat top side of gasket with Foliac jointing compound.
- Fit and bolt down cylinder assembly.
The boiler has already been tested hydraulically after fitting plugs into all the screw holes in the raised pad.
I would be most grateful for advice on sealing this important joint in preparation for a steam test.
Many thanks,
Martin McDonald
