Touchdown, new toy has arrived. Warco WM290V
Home Forums Manual machine tools Touchdown, new toy has arrived. Warco WM290V
Viewing 2 posts - 26 through 27 (of 27 total)
  • #661431
      The way to measure the tool size is to put the MT4 centre into the headstock and then measure from th ebottom of the slot in the toolpost to the point of the ctr and that will give the maximum height you can fit
      If using insert tools sometimes it may pay to come down a size so you can use smaller inserts which works out a bit cheaper so a 10mm sq shank would tend to take CCGT 06 but a 12mm sq shank CCGT 09. Ditto with HSS as it is a lot easier to grind the smaller sizes rather than the max and you will only really need the max shank if you have excessive tool overhang. I mostly use a mix of 8 & 10mm on my 280 which suits the work I do.
      Rob Wheatley
        @robwheatley66643
        I'm using 16mm tooling on mine now but I do have a quick change toolpost and have milled all the holders out to take them.
        Seems a lot more rigid and less prone to chatter with them, I do use inset tooling and take quite heavy cuts though.
        Glad you have it going now.
        What do you think of it? Only thing that annoys me is the controls not having a stop button, might look at adding one now it's out of warranty.
        I did have to sort my steady rest out too, the adjustment threads were stripped out the first time I went to use it!!
