Charadam, you are a jinx
I read your post last night and thought why does he need them I,ve never lost one.
Then I went out to the workshop to look at making a tool holder for some ccmt 11 tips I got by mistake. I found a spare M 2,5 torx X from an SCLR boring bar that I wrecked and set to on the job. 10 minutes later, ping off it went. An extensive search with a cloth wrapped round a strong magnet failed to find it.
So now I have the same problem as you. Not easy to find a supplier is it.
Chronos do them at 85 p each ! so I tried dear old flea bay and at the third search attempt using ” ccmt inserts” I came across a guy tony4cats selling 10 of the above for £4.75 inc postage.
So mine are on the way on Monday I hope that is of use to you.
Make sure you get the right ones as the smaller ccmt tips can use M2 torx.
Regards Clive
Edited By Clive Farrar on 24/01/2010 17:38:08
