Posted by Jim Nolan on 04/04/2015 08:40:27:
Posted by John Stevenson on 28/03/2015 11:10:50:
Another big 'bug' [ or is it a feature ?
] in Linux CNC is if you break a tool, you can't jog away, change the tool, set the new offset and go back and continue machining. You have to re-start from line 1.
So does that mean there is no run from line X. Which then brings up the dialog box in Mach3 which it took me loads of mistakes to learn the correct answer was cancel not yes? ![](data:image/gif;base64,R0lGODlhAQABAAAAACH5BAEKAAEALAAAAAABAAEAAAICTAEAOw==)
Run from line works well with linuxcnc
