Hi Steve,
Many thanks for your quick replies which were over night for me in Australia. I was about to send my reply to your first two messages until I discovered your third one. This is what I was about to say :-
Yes, I’m inclined to agree with you that it’s muck, especially since the only parts now involved are the top-slide lead-screw, the nut (keyed into the rotary bracket with a tiny grub-screw along its edge ), and the rotary bracket (wheel?) used for indexing the top-slide around when taper turning.
The jamming appears to be around the tip of the lead-screw inside the rotary bracket, and I’ll only find that out by removing the nut. Since it’s not my machine, I’m rather concerned that the lead-screw may have partially seized, and that removing the nut may introduce another problem. Like a bad tooth, it has to come out.
When the garage gets a bit warmer this morning, I’ll try to `persuade’ the lead-screw nut to come free. With the grub screw (key) out of the way, I plan to use the tail-stock and a short length of rod to push on the end of the lead-screw. It’s been left with a centring hole so I should use a corresponding rod tip to avoid damaging the lead-screw tip.
Amongst a variety of changes, and if the machine were mine, I would plug the clearance hole for the stop-slide lead-screw since it is ideally placed to catch swarf.
I also agree with your comments about the gib strips which have been cut away in several places to provide flat seats for the adjusting screws. They are weakened as a result, and are prone to bending. And, if the screws are not located correctly, the strips do appear to jam.
My concerns about the back-lash were largely in relation to the possibility of a second nut inside the rotary bracket, whereby the back-lash would be reduced during manufacture. As you indicate, it’s not the case.
As an addendum in response to your third reply:-
I agree that the alignment should be done with the lead-screw wound in as far as possible such that the best alignment is achieved. The fixing screw clearances through the end plates allow for this. I was actually up to this stage when the jamming occurred . Because of the tendency for the gib strips to move/bend, I was more inclined to adjust their final sliding fit before the lead-screw was in position (a method I’ve used when I had my well-loved Myford ML7). Rather than winding the lead-screws in and out, it is much quicker to be able to push the slide to and fro.
Thank you for your patience Steve.
Best regards,
Sam Stones
