Tools explained
Tools explained
Home Forums Workshop Tools and Tooling Tools explained
  • #97090
    John Coates
      @johncoates48577
      Tools Explained:
      DRILL PRESS: A tall upright machine useful for suddenly snatching flat
      metal bar stock out of your hands so that it smacks you in the chest and
      flings your beer across the room, denting the freshly-painted project which
      you had carefully set in the corner where nothing could get to it.
      WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under
      the workbench with the speed of light . Also removes fingerprints and
      hard-earned calluses from fingers in about the time it takes you to say, 'Oh
      SKIL SAW: A portable cutting tool used to make studs too short.
      PLIERS: Used to round off bolt heads. Sometimes used in the creation of
      blood-blisters.
      BELT SANDER: An electric sanding tool commonly used to convert minor
      touch-up jobs into major refinishing jobs.
      HACKSAW: One of a family of cutting tools built on the Ouija board
      principle… It transforms human energy into a crooked, unpredictable motion,
      and the more you attempt to influence its course, the more dismal your future
      becomes.
      VISE-GRIPS: Generally used after pliers to completely round off bolt
      heads. If nothing else is available, they can also be used to transfer intense
      welding heat to the palm of your hand.
      OXYACETYLENE TORCH: Used almost entirely for lighting various flammable
      objects in your shop on fire. Also handy for igniting the grease inside the
      wheel hub out of which you want to remove a bearing race.
      TABLE SAW: A large stationary power tool commonly used to launch wood
      projectiles for testing wall integrity.
      HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after
      you have installed your new brake shoes , trapping the jack handle firmly
      under the bumper.
      BAND SAW: A large stationary power saw primarily used by most shops to cut
      good aluminum sheet into smaller pieces that more easily fit into the
      trash can after you cut on the inside of the line instead of the outside edge.
      TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of
      everything you forgot to disconnect.
      PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids or
      for opening old-style paper-and-tin oil cans and splashing oil on your
      shirt; but can also be used, as the name implies, to strip out Phillips screw
      heads.
      STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to
      convert common slotted screws into non-removable screws and butchering your
      palms.
      PRY BAR: A tool used to crumple the metal surrounding that clip or bracket
      you needed to remove in order to replace a 50 cent part.
      HOSE CUTTER: A tool used to make hoses too short.
      HAMMER: Originally employed as a weapon of war, the hammer nowadays is
      used as a kind of divining rod to locate the most expensive parts adjacent the
      object we are trying to hit.
      UTILITY KNIFE: Used to open and slice through the contents of cardboard
      cartons delivered to your front door; works particularly well on contents
      such as seats, vinyl records, liquids in plastic bottles, collector magazines,
      refund checks, and rubber or plastic parts. Especially useful for slicing
      work clothes, but only while in use.
      SON-OF-A-***** TOOL: Any handy tool that you grab and throw
      across the garage while yelling 'Son of a *****!' at the top of
      your lungs. It is also, most often, the next tool that you will need.
      Have you seen that alternative to wd40 , its called "start ya ******* " , it really does say this on the tin !!!!
      John Coates
        @johncoates48577
        “Borrowed” from a motorbike forum
        #97092
        Andyf
          @andyf
          A few more:
          ELECTRIC HAND DRILL: Normally used for spinning pop rivets in
          their holes until you die of old age.
          SKILSAW: A portable cutting tool used to make studs too short.
          WHITWORTH SOCKETS: Once used for working on older British cars
          and motorcycles. Now mainly used to impersonate the 9/16
          or � socket you've been searching for the last 45 minutes.
          E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any
          known drill bit that snaps neatly off in bolt holes, thereby ending
          any possible future use.
          CRAFTSMAN 1/2 x 24-INCH SCREWDRIVER: A very large pry bar that
          inexplicably has an accurately machined screwdriver tip on the end
          opposite the handle.
          AVIATION METAL SNIPS: See hacksaw.
          INSPECTION LIGHT: The home mechanic's own tanning booth. A good source of vitamin D, "the sunshine vitamin," which is not otherwise found under cars at night. Health benefits aside, its main purpose is to consume light bulbs at
          about the same rate that 105mm howitzer shells might be used during, say, the first few hours of the Battle of the Bulge. More often dark than light, its name is somewhat
          misleading.
          Andy
          #97096
          Ady1
            @ady1
            Philips screwdriver: A device for the efficient removal of crossed slots from screwheads
            Edited By Ady1 on 25/08/2012 10:35:16
            #97108
            GaryM
              @garym
              Thanks John, Andy and Ady. Still laughing.
              Gary
              #97116
              _Paul_
                @_paul_
                Lol thank you gents laugh
                #97118
                Swarf, Mostly!
                  @swarfmostly
                  Not a tool, but …
                  Swarf: a floor covering material used to save valuable components and small tools from daylight and discovery.
                  Best regards,
                  Swarf, Mostly!
                  #97136
                  Steve Garnett
                    @stevegarnett62550
                    Oh, there are more – mostly American, so I Anglicised them:
                    Phone – Tool for calling your neighbour Chris to see if he has another hydraulic floor jack.
                    Snap-On Gasket Scraper – Theoretically useful as a sandwich tool for spreading mayonnaise; used mainly for getting dogshit off your boot.
                    Timing Light – A stroboscopic instrument for illuminating grease buildup on crankshaft pulleys.
                    Tweezers – A tool for removing wood splinters.
                    Air Compressor: A machine that takes energy produced in a coal-burning power station 200 miles away, and transforms it into compressed air that travels by hose to a pneumatic impact wrench that grips rusty suspension bolts last tightened 40 years ago by someone in Abingdon, Oxfordshire – and promptly proceeds to round them off.
                    Grease Gun: A messy tool for checking to see if your grease nipples are still plugged with rust.
                    Radial Arm Saw: A large stationary power saw primarily used by most workshops to scare neophytes into choosing another line of work.
                    Edited By Steve Garnett on 25/08/2012 22:37:12
                    #97138
                    Steve Garnett
                      @stevegarnett62550
                      Horizontal Belt Linisher: A tool which, when turned on, will promptly project and distribute anything left on top of it in a pretty straight line behind it. Please don't ask me how I know this…
                      Machine light: A tool which demonstrates errors in your work, directly in proportion to how bright it is.
                      Edited By Steve Garnett on 25/08/2012 22:48:38
                      #97143
                      Andyf
                        @andyf
                        From personal experience today:
                        HEIGHT GAUGE: An instrument which will prompt you to find out what scrap iron is worth when used in conjunction with a surface plate to check if the bearing surfaces above and below the saddle of a Chinese lathe are in parallel planes .
                        SCRAPER: something you will need after finding how little the scrapyard will pay.
                        ANGLE GRINDER: used in the Far East to create dovetails etc, and in the West as a time-saving precursor to the scraper.
                        Andy
                        #97144
                        Springbok
                          @springbok
                          Thanks for the laugh
                          #97675
                          Ian Welford
                            @ianwelford58739
                            A couple more observations
                            Superglue – adhesive developed for space programme to ensure astonauts do not come loose from the spacecraft one stuck. Excellent for attaching self to project which you have just degreased and dried so it can adhere perfects but it just choses to attach you ( ignoring grease on hands, clothes etc) in preferance to the parts you wanted attached.
                            Note- NEVER try to remove tube stuck to fingers with your lips . No don't ask but it was a good 20 minutes before we took my brother to casualty ( couldn't drive whilst crying with sympathy- honest ! )
                            Cellulose thinners excellent cleaning agent for degreasing, alos good for removing "unbreakable handles" from screwdrivers. Again don't ask!
                            Router method of making vast amounts of wood dusk which settles ( eventually) on the freshly painted model in the next room, Said dust is capable of travelling through the time space continuum via closed doors and just to attach to the model.
                            Machine Worklight – device for warming hand in cooler weather and generating smoke when "coolant spray" hits the bulb. Designed to direct light to just reflect off your safety glasses whilst obscuring view of the work with it's shade.
                            Quick release air fitting – method of taking compressed air from the compressor to the airtool and refusing to part with it until begged!
                            #97682
                            I.M. OUTAHERE
                              @i-m-outahere
                              Very funny !
                              The skit about the engine starter was from a show called the comedy company that ran here in Australia .
                              How they didn't cop a law suit from WYNNES is beyond me !
                              They also did a skit featuring a suspension repair spray call the suspensions r**ted and one for the whole car is r**ted .
                              It was hillarious !
                              SHIFTER /ADJUSTABLE WRENCH : Used to machine the hexagonal flats from bolts and nuts , also doubles as a hammer .
                              STILLSONS /PIPE WRENCH Used to apply a knurl to the bolt heads that were macined by the shifter or anything else that is deemed too round to get a spanner on, also doubles as a hammer – should come with instructions as some can't seem to come to GRIPS with the fact they only grip in one direction .
                              IAN
                              #97688
                              Joseph Ramon
                                @josephramon28170
                                Obviously inspired them to dreate the 'real' product:
                                Presumably it's like Bradex Easy Start – ether and various other nice-smelling things in an aerosol.
                                Joey
                                Edited By Joseph Ramon on 03/09/2012 09:27:19
