Hello Rod, I use the spark eroder to make a form tool for the radius.
Take a piece of HSS say 3/32"x 1/2" and 2" long. Grind a chamfer across on end at about 8 or 10 degrees, full depth.
Clamp the HSS in a small tool makers vice, face up, at about 5degrees with the chamfer at the high end. Clamp to the table of the spark eroder.
Turn down the end of a piece of copper rod to 0.002"diameter less than twice the radius you want to form, by about 1/4" long. Fasten in the chuck of the spark eroder.
Bring the quill down until the copper overlaps the end of the HSS. Move the HSS horizontally until it touches the copper. Raise the electrode clear and advance the HHS the depth of the rounding. Erode the end of the HSS.
You can space a number of different radii across the end of the HSS
For your single point screwing tool use a tubular electrode the inside diameter 0.002" larger in diameter than twice the tip radius and the elecrode machined away until only the depth of rounding plus the wall thickness remains.
Edited By John Ockleshaw 1 on 23/09/2012 03:47:38
