Tool Profile
Tool Profile
Home Forums Beginners questions Tool Profile
  • #54899
    Howard Warehand
      @howardwarehand
      I have a Circular Ali Plate (Disc) 100 mm Diam by 10mm thick already mounted on a face plate. I want to machine a circular 2mm x 2mm groove into the face of the plate.
      My problem is that I have ground up a tool for the job with a profile similar to a cut off tool (squared off beak type of thing) but with adequate clearances. The tool nibbles rather than cuts cleanly and tends to squeal rather than cut. Any ideas please on what the profile should be or any other suggestions.
      Thank You
      Howard Warehand
        @howardwarehand
        For Machining a Circular Groove.
        #54900
        Ramon Wilson
          @ramonwilson3
          Howard,
          You don’t say what diameter this groove is. Depending on that the tool will need side relief on the outer side to clear the outer radius – that may be the problem. The tool should have a small amount of top rake – five or so degrees and be set at or just below centre height and the speed set at ‘roughly’ suitable for the diameter to be cut.
          If its nibbling and squealing as you say check the actual cutting edge too as you may have a small land that is causing it to rub.
          You really shouldn’t have too much problem getting the tool to cut ally if the tool is shaped and relieved suitably.
          Hope this helps to begin with – good luck
          Ramon
          Just a second thought but how is it mounted to the face plate ?
          Edited By Ramon Wilson on 30/08/2010 21:10:49
          #54901
          ady
            @ady
            Aluminium should never give you any issues, it’s one of the easiest softest metals out there.
            So it must be your setup.
            The only serious trubble with aluminium is too much heat can make the chips weld to the tooltip, almost as good as anodising, so sometimes you have to use a slow speed and high torque to munch chips with less heat.
            Tooltip height, width, front relief, side relief(both sides) and general setup stiffness must be at issue somewhere.
            Squealing often indicates a flatspot just under the tip which can be shaved out with a few gentle touches, also, a parting style tool is easy to get wrong because they can be too big for the machine if we grind one ourselves, plus the relief needs to be done properly on all three vertical sides, as well as the top.
            Moving the tip slightly from left to right as you cut can also help.
            All part of the learning process. : )
            Edited By ady on 30/08/2010 22:20:19
            #54902
            John Stevenson 1
              @johnstevenson1
              My trick for a circular form tool is to braze a ball bearing of the correct size onto a piece of mild steel.
              The sticky out bit need to be a tad less than the OD of the ball.
              Then grind the top of the bearing so that it’s reduced in hight by half and thats it, all clearances are present and you have a perfect sphere.
              John S.
              #54933
              Lawrie Alush-Jaggs
                @lawriealush-jaggs50843
                That’s cheating John.  Bloody clever though!
                #54951
                Howard Warehand
                  @howardwarehand
                  First, my grateful thanks to all who passed on such helpful information, it helps to lessen the learning curve!!. OK now its confession time!!!!. I collect HSS tool blanks whenever I get the chance (shows etc) and use them for odd jobs such as the one in question. On closer inspection it appears that the blank I picked from my stock isnt HSS   , in fact I can file it quite easily!!!!!!. This explains why after regrinding it would cut OK for a few revolutions then quickly stop cutting. A HSS replacement will be prepared at the weekend,and together with your ideas and suggestions, I should have a better result.
                  Thanks again to all,
                  Edited By Howard Warehand on 31/08/2010 21:13:48
                  #55144
                  Howard Warehand
                    @howardwarehand
                    Good result when using the right tool steel!!!!!!. I guess the lesson is to make sure I buy from a reputable source and that bargains are not always bargains.
                    However I’m pleased that I posted the question on the forum because it brought up some useful ideas from you chaps.
                    Thanks again for your help,
                    #55151
                    Billy Mills
                      @billymills
                      If you suspect that you may have a clearance problem when using an unusual shape tool you can always blacken the tool with a felt tip marker pen then take a quick cut and see where the shine is.. That would also reveal an edge that retreated too quickly by showing the flat.
                      Think that Sir John Unslotted Stevenson’s idea is absolutly brilliant. Some balls are made by two contra-rotating plates with spiral hemispherical cuts to roll form a sphere, John’s idea might be how the plates are fabricated. Some balls from bearings and some glass marbles are made that way.
                      Unslotted Alan.
