So, not changed that motor yet.🙂 Just consider whether a motor, of twice the power, would have stalled, when you overloaded it, or whether twice the power would have broken something more than just one tooth off the end mill. No point in having the belt slip with a more powerful motor, either – might just as well keep the current motor and be able to use all its power (than fit a bigger motor and only use half of it).
I noted the VFD did not trip out on overload. Is it set correctly, I wonder?
First impressions certainly count – I looked back at your earliest thread, a while ago, and thought how could someone (with such apparent wide experience) not be able to sort out a simple conundrum as that (change gears and what the tumbler gears do – what with so many youtube videos on the subject). But never mind, you are certainly demonstrating your inexperience on the vids. Good for all to see how not to do it.🙂 But you are now taking note and learning, so progress. I do like your sense of humour, at times (amongst the mumblings🙂
. Keep it up and you will get there – rather faster than some, I am sure.
My final cuts are generally just a very slight turn on the depth/width (a couple hundredths of a mm, if that) and climb mill. Usually improves the finish considerably.
Slitting saws notoriously cut only on part of the circumference better than the rest. One needs to feed sufficient to utilise all the teeth (to avoid some teeth ‘rubbing) but not so much that the gullets fill with swarf. A few less teeth might have been advantageous for a job like that, although a decent band saw might have been a better choice for the job. Certainly better to be left with a piece of useable material rather than converting it into swarf, if possible.
I see progress, for sure.
Edited to add: Who cares about the size of the roughing cuts (+ or – a few hundredths), its only the finishing size that is important – and only for the dovetails on a tool holder. Especially as you seem to be going to make the slot for the cutter wider than the bought-in example.
And to try to remove those silly emoticons the system adds in for brackets, etc
Edited By not done it yet on 14/04/2020 09:36:24
