Started to put this one in the "What did you do today" thread but looked so pretty when it was done it deserves it's own shelf in the Lodge.
Started out with this.
The shaft on the right needs the same splines as the one on the left. It's off something to do with a fork truck transmission and no spares. Ideally it would pay to change the shaft and gear but the 6 spined gear is larger, narrower, and the offset of the dished gear is wrong.
So first thing and this shaft is hardened is to remove some of the shaft and the 6 splines to get under the surface. So in the lathe and using resharpened carbide tips as they won't last long, rip big lumps off. No picture as it's straight forward.
Then build up with weld. The idea is to get the splined end hot so it becomes soft but not allow the pinion to become hot. So weld a bit and let it cool with the pinion under water.
This achieves two things, it keeps the pinion hard and also warms up last nights coffee.
Proof of which is in the photo below, no HAZ on the pinion, and the coffee was lovely.
Throw it back in the lathe and simple turning and we get a blank shaft.
Next bit is hobbing the splines on the old converted Victoria U2 mill. As I only have one bit of the cherry or redo everything again I cut a dummy shaft and checked for fit. I fed the hob in the the text book depth and it came out a nice tap fit onto the gear.
However the hobber has an ER32 inbuilt collet chuck and no way will this pinion fit in so I made a tempory pot chuck with a 20mm spigot to fit the ER32, a ball bearing for a centre and two M5 grub screws as driver dogs to turn the pinion when in the machine.
So cut the spline, only a short one 18mm long and check for fit on the gear, dummy shaft to the right.
All done and dusted, just requires going over the road to the heat treat plant to have the splines induction hardened.
Could do it with a torch and dunk the end but these guys have all the gear and know what they are doing, plus I can get on with something else.
Pie and a pint time……………………………..
