Greetings peeps.
Todays bodge is quite a common one.
![](data:image/gif;base64,R0lGODlhAQABAAAAACH5BAEKAAEALAAAAAABAAEAAAICTAEAOw==)
Armature out of a fork truck motor, the one that drive the hydraulic pump for ancillaries. This one has suffered a pump seizure which in turn has twisted to Oldham drive dog off.
In the long distant past I have built these up with weld and machined them back but never felt happy about the strength of them even though I have never had one back. So now I choose to do them a different method that I feel is stronger.
First a very detailed CAD drawing of the armature is made.
Then the armature is run in a steady to get a dummy centre in the end to reduce the diameter down by a mill or so to get the weld transition below finished size.
Then transfer to the Blidgeport and mill a slot into the end, same width as the dog, 8mm in this case.
Next job is then to cut a piece of hardaswitchestitsium [tm] to act as a dog and fit it in the end.
Note the dog has purposely been cut narrower where it fits into the shaft to allow the weld to get hold.
Then it's all welded up.
Back in the lathe, on the steady which is still set up, face to length then small centre in the end, dispose of the steady and turn to the original diameter.
Jobs a good un and another £3 17s and 6d to add to the pension fund which at present rates should mature about 3 years after I am dead.
