Greetings to all my weld it where it touches fans.
Todays little problem landed on the floor, literally at dinnertime today.
It's a brake rotor out of the electric motor that opens the local fire station door. Pretty standard motor bus has a brake extension to hold the door in a given position. That chewed up bit should be 22mm plus a gnats cock with a 6 mm keyway in, far end is worn but this just carries a fan.
So need to get this sorted as they have three firemen all called Dennis standing on each others shoulders holding said door up.
Three things to do, buy a new motor, not going to happen as it was made in Outer Mongolia in 1921.
Press shaft out and make new shaft and press in, lot of work just for two diameters.
Three, weld worn bits up with 21 miles of 1.2mm MiG wire and machine back, sounds a winner to me.
So turn both diameters undersize so the weld transition isn't on the finished diameter and splat some weld on then bung it back in the lathe before it has time to dry.
Welding rotors is like plucking chickens, best done whilst hot but you can only go so far as the last few cuts has to be at room temperature otherwise when it does cool off you are way undersize. So belt it down to 23mm and leave.
Then get a phone call because the rewinders have found out 22mm brake hubs are obsolete so can I do it to 25mm.
Weld up yet again, rinse and repeat.
If they have a long shaft extension I do them this way as the bit in the chuck I know is running true because of the soft jaws and the bit in the tailstock centre is also true and being red hot running it get the shaft pretty straight to get the bulk off. Once cool if it's critical like a bearing diameter then you can swap to a steady to get true support.
Welding in the middle of a long shaft and running off centres at each end is an exercise in futility, it will be like a banana.
Final cut on a cold shaft, thats 0.02 up just requiring a final polish.
End job with the keyways in, just needs reassembling and the 3 Dennis's will be able to nip home for their tea.
Please note, no microns or scraped surfaces were harmed in the making of this post.
Stay tuned for more from Bodgers Lodge
