To Web Master
To Web Master
Viewing 25 posts - 51 through 75 (of 82 total)
  • #47874
    David Clark 13
      @davidclark13
      Hi There
      I will try and get it sorted.
      I can’t get to the bottom of the post to delete it.
      regards David
      Les Jones 1
        @lesjones1
        Hi David,
                         I can see that you have managed  to delete what was the third reply. The problem now seems to have moved to just after the last character of my test reply. The bottom slightly darker grey box which normally contains “Message members” etc is missing.
        This is using IE8. Using Firefox  it looks OK
        Les.
        #47878
        David Clark 13
          @davidclark13
          Hi There
          Have deleted post.
          Has this sorted it out?
          regards david
          #47883
          Les Jones 1
            @lesjones1
            Hi David,
                               Yes it looks like you have fixed the problem. I have not tried adding a test post but the box to enter the text is now there as is the button to post it.
            I imagine problems like must eat into your time. I suspect it was not as simple as just hitting a delete button somewhere.
            Les.
            #48005
            Ian S C
              @iansc
              Should I be getting two different foremats at random times, it does’nt worry me just curious. The normal format has the adds on the right side, and is the one I prefer.The second has large print, but its not so easy to find the log on box for example.Ian S C
              #48006
              David Clark 13
                @davidclark13
                Hi There
                No, totally wrong.
                You have an error somewhere.
                Forward more details.
                regards David
                #48007
                Ian S C
                  @iansc
                  David, apart from it starting last Sunday/or was it Saturday,about then, theres not really much I can say,I’v been waiting for someone else to ask,think I’ll just wait and see.Thanks Ian S C
                  #48008
                  KWIL
                    @kwil
                    Ian
                    Whe  you have large format have you tried [Ctrl+scroll] to change/reduce the format to normal?
                    Edited By KWIL on 29/01/2010 14:08:24
                    #48040
                    Ian S C
                      @iansc
                      Kwil, the lay out of the two formats is totally different,they don’t look related to one another apart from the fact that all the information is the same.I don’t know much about computers,Iknow were Ctrl is, butscroll, is there a key for that? I tried clicking on the scroll bar on screen. Ian S C
                      #48045
                      KWIL
                        @kwil
                        Ian,
                        Scroll is the roller on top of some mice , the [ctrl+scroll] allows you to change magnification.
                        #48057
                        Frank Dolman
                          @frankdolman72357
                               I have had this too, also at random.  It usually reverts ( perhaps”pops”
                             would a better word ) to normal after a second or so but sometimes it
                             lasts for a whole session
                          #48080
                          Les Jones 1
                            @lesjones1
                            Hi all,
                                      For someone to look into this problem they will need to know which browser and operating  system suffer with it.
                            Les.
                            #48087
                            Ian S C
                              @iansc
                              Hi Frank, good to know I’m not the only one, your description sounds the same as mine.Thanks Kwil, must have a fiddle with it and see what happens. Ian S C
                              #48184
                              Frank Dolman
                                @frankdolman72357
                                     The “Spindle Speed” thread is coming out overlaid by the
                                  ads on the RH side
                                #48187
                                DMB
                                  @dmb
                                  Hi David,
                                  If I click on “Spindle Speed” in latest posts, part of thread text is hidden behind the latest posts box. Doesn`t happen to any others.
                                  John.
                                  #48191
                                  Keith Long
                                    @keithlong89920
                                    Hi
                                    Similar problem on the “Power Hacksaw” thread, also with a long url in one of the posts.
                                    Keith
                                    #48193
                                    KWIL
                                      @kwil
                                      I have just checked the above, NO problems using Firefox + XP
                                      #48194
                                      KWIL
                                        @kwil
                                        Cut and pasted the very long ebay URL in power hacksaws, worked straight away.
                                        #48196
                                        Keith Long
                                          @keithlong89920
                                          Hi Kwil
                                          Just re-checked it and I’m still seeing the same problem with adverts overlaying text. I’m using Firefox and XP as well, The problem doesn’t occur using IE v8, so could be a small coding error on that particular page. If the page has been written for IE then other browsers may not display everything correctly. Microsoft have a habit of not sticking strictly to the correct html protocols when it suits them not to. Can be a nightmare writing web pages to account for all the quirks and foibles between the various browsers.
                                          Keith
                                          #48587
                                          Circlip
                                            @circlip
                                            Hows about a “Mod” on the Sales and Wants Ads to include a ROUGH location of the users, so we can decide if it’s more cost effective to COLLECT rather than Royal Mail or some carrier trying to loose the said items and recently, I would have been delighted to have helped “Geoff” with his quest for an old M/E but HOW?? and the other, “LBSC parts and drawings”  of WHAT???
                                              Regards  Ian.
                                            Edited By Circlip on 12/02/2010 14:28:29
                                            #48588
                                            David Clark 13
                                              @davidclark13
                                              Hi There
                                              There is a space on the form for town.
                                              We can’t force people to declare what the castings are for and if someone places an advert but does not have a public profile, you can’t email them.
                                              regards david
                                              #49050
                                              Les Jones 1
                                                @lesjones1
                                                Hi,
                                                      After adding a post (About 09:40 23/02/10) to the thread “Low Price Optical rev counter accuracy” the view of the page was totally confused. I think there must be some hidden characters confusing the browser. Could you try deleting this post to see if it clears the problem.
                                                Les.
                                                #49057
                                                Les Jones 1
                                                  @lesjones1
                                                  Hi,
                                                        Many thanks for removing whatever was causing the problem on that post. I think I know what caused it I used “Word” to check the spelling of “fluorescent” and then pasted it into my post. I think some formatting characters characters must have been pasted in as well.
                                                  Les.
                                                  #50741
                                                  Swarfmaker Barry
                                                    @swarfmakerbarry
                                                    Access to the sample digital archive magazines under “Extra” appears to be broken.
                                                    It says: Click on the magazine covers below to test drive the digital editions.
                                                    Doing so has no effect for any of them.
                                                    (I tried using Firefox 3.6 and IE 7. )
                                                    Barry
                                                    #50745
                                                    Terryd
                                                      @terryd72465
                                                      I’ve had the same problem for several days now
                                                      Terry
