TNMG inserts
TNMG inserts
Home Forums Workshop Tools and Tooling TNMG inserts
  • #552334
    Vic
      @vic
      Anyone use them? I’ve finally got round to trimming down the tool holder for my lathe and was thinking of getting some of the polished inserts for it.
      Vic
        @vic
        #552356
        ChrisB
          @chrisb35596
          I use them, don't have the polished ones yet but I want to get some of them. I got my inserts from Cutwell, YG branded, in different tip radii. I find they work well in both deep and shallow cuts, but for shallow cuts or creeping to size I use a new edge. The polished ones may perform better. I also use one on my flycutter and it works very well.
          #552395
          Vic
            @vic
            Thanks Chris. The particular attraction for me is that although they are a similar cost to other inserts you get six cutting tips. I’ll order some polished ones to try.
            #552409
            old mart
              @oldmart
              We have three righthand and two lefthand holders for TNMG 16 inserts. One of each hand has an aluminium insert in it which is also good for fine finishing cuts on steel. I find that the cheap Chinese Drillpro brand for steel works very well. As Vic says, you get six edges as long as you don't knock the whole end off an insert. We have Sandvik, Seco, Kennametal, Iscar, Tungalloy and others bought cheaply on ebay. WNMG in 6 and 8 sizes are also good with six edges like TNMG. Try the cheap H01 grade if you are thinking of getting some for aluminium.
              Edited By old mart on 03/07/2021 12:50:10
              #552807
              Vic
                @vic
                I’ve ordered a couple from JB to try.
