Titanium
Titanium
Home Forums Beginners questions Titanium
  • #57595
    macmarch
      @macmarch
      Can anyone help with sourcing Titanium wire, grade 1,2,3, or 4?
      I need it at about 2mm dia and a total length of about 2 metres. I would also consider changing my design if it was available something like 1mm x 6mm flat in a hard condition.
      cheers
      Ray
      macmarch
        @macmarch
        #57596
        KWIL
          @kwil
          Have you tried http://www.titaniummetals.co.uk?. They list 2mm wire in two grades.
          #57651
          macmarch
            @macmarch
            Cheers Kwil,
            I had looked all over t’internet but no one actually sells small quantities, not even TML.
            If I order 2m of 2mm wire the cost is £75, call in and pay cash = no min order value.
            thanks
            ray
            #57653
            Anonymous
              #57654
              David Clark 13
                @davidclark13
                Hi There
                Have you tried jewellery suppliers?
                regards David
                #57655
                macmarch
                  @macmarch
                  If I go and collect from TML then price is small but will use £30 petrol. Twistfix gives 5 times as much delivered for less than the petrol. Classic example of not what you know but who you know. Thanks for all help. problem solved.
                  cheers
                  Ray
                  #57898
                  Tony Jeffree
                    @tonyjeffree56510
                    I have used reactive metals in the USA as a source of Titanium wire before now:
                    They are very responsive & don’t have a minimum order if I recall correctly.
                    Tony
                    #57900
                    John Stevenson 1
                      @johnstevenson1
                      Titek in Birmingham do exactly what you need.
                      Nice company to deal with, you want 200mm of 30mm Titanium and they will cut it and ship it. I buy just what is needed when I need Titanium because of the cost.
                      John S.
                      #57905
                      macmarch
                        @macmarch
                        I have now purchased a supply of Titanium.  It wasn’t the quantity that caused the problem but the size.  2mm wire. Nearly every source started at 6mm.
                        All I have to do now is to make plastic toolmakers clamps with the wire clamped at the bottom.  If it works as it should I’ll put the dwgs up for anyone else to use.
                        cheers all
