I prefer the TS250s to the ETZs (250 or 251) – less peaky power delivery & more economical, but the disadvantages of 6v electrics and drum brakes. I had one of the last DDR-era produced ETZ251s, (in a fetching shade of beige) rescued from my brother-in-law, who had bought it new but then lost interest & left it festering in a damp garage. Build quality had rather gone down hill by the end of the DDR, though. Didn't keep it long, though did do a round trip to the Ace Cafe for the first "Red October" East European bike day on it – near 400 miles in the day & a long way to go for an expensive, indifferent burger !
My late friend Mark Dicker was Classics Officer for the MZ Riders Club & he reckoned that the ETZs would disappear before the earlier bikes due to frame corrosion – the area of the frame that the footrest bar bolts to rots off. The frame is used as part of the inlet air system & heavier dust accumulates at the bottom of the frame – this gets & stays damp, causing the frame to corrode from inside. The TSs used a similar intake system, but the tubular frames were heavier gauge than the sheet steel box section on the ETZs, so they last better + the tube is blanked off with an easily removed plastic plug that enables the dust to be cleaned out. The ETZs have (IIRC – it has been a while) a welded on closure with a small, easily blocked, drain hole. May be worth checking this area on your tidy bike ?
I have 6 in various states of assembly & function – 3 off TS250/1, and ES250/2, an ES150/1 and an ETS250 G5 ISDT Replica , of which only the oldest TS250/1 (which I have owned for 29 years) is running. So many projects – so little time !
Nigel B
