Posted by Dave Halford on 04/04/2023 16:58:29:
In the case of the first link the National Physical Laboratory refers to American species such as White Oak. Doing anything suggested in that paper with English Oak will give you a big blue/black stain from the steel and if left there it will rust away.
Why do you think that? I'd have thought that the NPL would have considered quercus robur their 'default' oak.
At the risk of flogging a moribund nag, like I said, it's complicated… And there's a lot of misinformation being perpetuated.
Timber is largely composed of cellulose, a polysaccharide, and some of its sugar units are acetylated. These can react with water to produce free acetic acid. Timber is consequently acidic, some more than others: oak, sweet chestnut, western red cedar and Douglas fir are particularly acidic. Acetic acid is volatile, so a closed wooden box, with timber containing any water, is very likely to contain acetic acid vapour, and this will corrode the contents. This is a risk for many metals, including, perhaps surprisingly, lead, not just Fe-based materials.
Corrosion can also occur by contact with the timber surface, and this appears to be a particular problem with tannin-rich timbers, such as the oaks. The corrosion is caused by acetic acid, not the tannins. Acetic acid is a stronger acid than tannic acid. Nomenclature is often muddled in source material: quercitannic (sic) acid is a tannic acid found in oak. There are other tannic acids, and tannic acids are a sub-set of the tannins.
Tannins are a major component of some 'rust stabilisers', the ones which don't remove the corrosion, but turn it black: the red rust is converted into black tannate, which protects the substrate from further rusting. Tannates are also oxygen scavengers, but I don't think this attribute is important here. However, what this means is that, (if there's moisture around), steel in contact with oak may develop characteristic black corrosion damage. Tannins are not volatile, so this blackening shouldn't occur without contact. Tannins will also cause dark blue discoloration of non-corroded metal. The timber may also be stained around steel fasteners, for example, which will also corrode. Again, it is the acetic acid that causes the corrosion, but the tannins that turn the rust black. I suppose that when tools rust in association with other types of timber, it's generally thought to be 'ordinary', moisture-induced corrosion, and the contribution of acetic acid is not appreciated.
Bottom line: all timber is suspect if there's moisture about; keep things dry, sealed from any acid vapour emanating from the timber, and out of contact with the timber, particularly if it's a tannin-rich timber. Closed boxes are bad, boxes sealed in plastic bags are worse. Now that there are alternatives, perhaps timber storage boxes, drawers, etc. should be avoided.
