Ian – MIG is dead easy.
1. Get the right gas for mild. You can use CO2 (cheap) but it spatters like mad. Best is Argoshield 5, an for light work, and Argoshield 10 (AP will do equivalents) for something else I can’t remember.
2. If you can afford it get an arc operated face mask. Set up in the clear, and it darkens automatically. Helpful but not essential.
3. Must have- pair wire nippers.
So, connect earth, to trial bit of metal (clean and about 1/8″ thick for a start.) Press trigger to check for wire feed – listen for gas (purge line). Nip wire off 1/4 – 3/8″ from nozzle. with nippers to give nice sharp end for arc to strike on.
Set feed and amps according to makers instructions – try welding. Basically if the wire stabs forwards and/or burns back in an intermittent action you should up the wire feed (or turn down the amps). ie its striking and burning back so the feed rate is not enough to maintain a continuous weld.
If the wire sticks into the weld hard then turn down the feed rate. Its coming in too fast.
You should get a steady frying bacon noise, and when you stop, you should get a small blob on the wire (rule of thumb). As with all things amps wire feed and your speed along the work are all interlinked, but its pretty accommodating. Most welders have a series of steps for amps, and so assuming you are in the right step or range, its easier to adjust feed.
Experiment – its not that difficult.
Going for a decent weld, assuming you don’t have a welder with a special start setting and a dwell for finish, which most of us don’t.
Start a little way into the weld, come BACK, and then go forwards over your start. This ensures you have adequate penetration at the beginning of the weld. At the end, don’t just stop. Dwell for a second or so, then shut off. Stops that dimple, which is not great technique.
Vertical down is a matter of getting settings right and it’ll run perfect. Vertical up is little triangles.
Once you have had a go and can get the thing to run you can start moving the torch left and right to get leg lengths right as specified on the drawing.
Seemples.
TIG will produce beautiful welds, and manganese bronze too. On ali and magnesium its the dogs. But you need to do a bit of practise or train under instruction. Its very easy to get it imperially wrong!!!! Especially in thin ali, or anything else thats hot short. And its going to cost a grand or better to get a good fully versatile set..
Edited By meyrick griffith-jones on 01/11/2009 22:59:17
Edited By meyrick griffith-jones on 01/11/2009 23:04:05
