what do you mean the tungsten is burning back
At low amps as you describe there should be no danger of this even a 1mm tungsten should be good for 60 amps plus a bit you shouldnt be above 35 amps asa start for what your joining a good rule of thumb is 1 amp per thousandths of an inch up to 1/4" thick and 1.5 amps per thou thereafter
we join steel in the 0.6mm to 6.35mm thick range daily and readily 0.9mm wall tube gets welded to 6.35 plate and thicker with no problems whatsoever but i spent years on a miller syncrowave welding thinwall bicycle frames together
1mm sheet is quite thick in my world do you have a footpedal? and understand frequency control for the AC higher means a tighter arc and less wander but it also means your mre likely to penetrate through
tungsten grind angle you might want to try greater than 30 degrees for less penetration
IME pulse welding aluminium is very hit and miss you are much better using freq and foot pedal you max amps will be set on the machine and that is what you have on tap at the pedal, no more
Using pulse means you have to take into account your on, off time and account for that if you are welding 30 amps peak for 0.2 seconds you dont have a chance of starting a bead you need to go up on your peak amp to near 90 amps
the one honest to god true thing i will tell you when it comes to welding thin material is you do get what you pay for with a more expensive welder that goes down to 3 amps ,sure many will say 3 amps is the lowest they will go but when you compare arc stability side by side of a high end machine to a an adequate far eatern machine you see the difference
