An interesting question [and a very informative link, thanks]
I think the key to finding the answer will be a thorough appreciation of those tolerances … from which it should be possible to deduce the relevant three-wire measurement.
[quote]
Normal tap tolerance is ISO 2 (6H), which generates an average quality fit between screw and nut. Lower tolerance (ISO 1) generates a fine fit without a gap on the flanks between screw and nut. Higher tolerance (ISO 3) generates a rough fit with a large gap. This is used if the nut is coated, or if a loose fit is preferred. Between tolerances 6H (ISO2) and 6G (ISO3), and between 6G and 7G, there are also taps with tolerance 6HX and 6GX. “X” means the tolerance is outside the standard and is used for taps working with high strength or abrasive materials such as cast iron. These materials do not cause oversize problems so higher tolerance can be used in order to increase tool life. The tolerance width is equal between 6H and 6HX. Forming taps are usually produced with a 6HX or 6GX tolerance.
[/quote]
… My brain hurts already !
Edit: __ This might be a good rabbit-hole to start exploring:
https://thegauge.co.uk/thread-tech-specs
Edited By Michael Gilligan on 13/08/2023 05:02:29
