Three Cylinder Steam Radial
Home Forums Stationary engines Three Cylinder Steam Radial
  • #3050
    Stewart Hart
      @stewarthart90345
      Three Cylinder Radial Made from bar stock
      Stewart Hart
        @stewarthart90345
        Just completed this Three cylinder radial derived from the Cygnet Royal, and Elmers Radial engine, with additional design changes.
        Her’s a video of it running
        [IMG]http://i431.photobucket.com/albums/qq32/sbwhart/Rotary%203%20cylinder%20steam%20engine/IMG_2029.jpg[/IMG]
        Enjoy
        Stew
        #47742
        Doddy
          @doddy
          Lovely – Enjoyed the vid and the photos
          #47771
          Stewart Hart
            @stewarthart90345
            Hi David
            Thanks for your kind comments, it was a real enjoyable engine to build, if you look on the madmodder.net forum you can follow the build log, just do a search for three cylinder radial and you’ll find it.
            All the best
            Stew
            #47776
            Paul Boscott
              @paulboscott25817
              Stewart
              Watched your video what is the valve system you have used ?
              Paul
              #47777
              Stewart Hart
                @stewarthart90345
                Hi Paul
                It uses an orbital valve, I tried taking a video of the valve action with the steam chest cover off but couldn’t get the vocus correct. Basicaly what you have is two flats at the end of the crank these engauge with a slot on ta return crank which has an off centre drive pin that drives the orbital valve openening and closeing the valve ports.
                If you email me on sbwhart@yahoo.co.uk  i’ll post you a sketch of the system.
                Cheers
                Stew
              Home Forums Stationary engines Topics
