When “Dieing” a thread George, the face of the die with the writing on is the one to present to the work, which leaves the unthreaded witness. If you want more thread, after the initial threading, turn the die over so that the “Back” face is presented to the work.
The lead face usually has a taper relief whareas the back one hasn’t. If you want tighter threads, chat someone up with a suface grinder and have the back face skimmed.
BEWARE trying to cut the whole length “Backwards”, the thread WILL run off.
Regards Ian.
