Thread locking inside boilers
Home Forums Locomotives Thread locking inside boilers
  • #582105
    John Billard 1
      @johnbillard1
      What is the best sealant to use these days for screwed joints within a 5" gauge boiler when subsequent access might be "difficult".
      Best wishes
      John B
      John Billard 1
        @johnbillard1
        #582107
        Former Member
          @formermember12892
          #582108
          Former Member
            @formermember12892
            #582109
            Former Member
              @formermember12892
              #582118
              KWIL
                @kwil
                br,
                It must be something you do, does not happen to me!
                #582127
                Grindstone Cowboy
                  @grindstonecowboy
                  Not saying it's the cause of multiple posts, but I sometimes double-click where I should single-click.
                  And to (partly) answer John B's original question, I'm afraid I've never built a boiler. However, I have had success with this for other sealing requirements, and I'm sure I read somewhere that it's suitable for steam. Doubt whether it has any thread-locking capabilities, though.
                  Rob
                  Links to https://rectorseal.com/rectorseal-tru-blu-group/
                  #582256
                  John Rutzen
                    @johnrutzen76569
                    Hi, I think Loctite is ok with steam for say screwing a thread into a boiler to hold on a support bracket but it does lose it's strength as I found out. I had screwed my regulator rod into the cam it used to operate the device and sealed it with loctite. I steamed up and wondered why the loco wouldn't move – the thread had unlocked itself! So I don't know of any thread sealant which will do anything other than seal inside a boiler.
                    #582302
                    John Billard 1
                      @johnbillard1
                      Thanks for the replies. I am just interested in sealing threads at the moment e.g.main steam pipe in to the regulator and oil pipes etc into unions/bushes.
                      Farmer para 287 uses Boss White but this was 1964.
                      John B
                      #582311
                      Paul Lousick
                        @paullousick59116
                        I used graphite sealant on the studs that screw into the barrel on my boiler. Graphite based compound is the traditional sealant for threaded and flanged connections on steam engines.
                        #582314
                        old mart
                          @oldmart
                          Google Loctite thread sealants to get the exact specifications.                   https://www.turtle.com/ASSETS/DOCUMENTS/ITEMS/EN/Loctite_21472_Catalog.pdf
                          Edited By old mart on 25/01/2022 12:24:09
                          #582377
                          John Purdy
                            @johnpurdy78347
                            I have used Loctite PST high temperature  thread sealant #567 on my boiler fittings (internal and external), for many years and have never had a problem. Its a white paste in a tube, Loctite part #56747. It doesn't set hard so fittings can be easily removed in the future. According to the spec sheet its strength reduces to 55% of initial strength after 1000 hours exposure at 250C (482F). That's equivalent to a boiler pressure of about 550 PSI.
                            Edited By John Purdy on 25/01/2022 18:20:19
                            Edited By John Purdy on 25/01/2022 18:51:58
                          Home Forums Locomotives Topics
