Hi Guys,
For thse of you who like the idea of a self lifting/clapper box/swing up tool holder have you seen the You Tube videos of what may be the original idea? If not may I suggest that you take a look at the following,
The first one was up loaded in June '09, some months before the excellent series by Bogs, but I cannot speculate as to whether this was before Mr M. Cox proposed his version, which Bogs perfected.
The German version is a piece of p*ss to make and works well. There is enough information to be had from the videos to make your own, well there should be enough there for any one who calls them self a model engineer
, the only part that is not blatantly obvious is that the cutting tip should be above the height of the pivot point. This design point is common to all the various versions as it encourages the tip to move back slightly as the tool lifts.
chriStephens
Edit, you will note that in the videos the top slide is set parallel to the lathe axis, but he still manages to get a good thread!
Edited By chris stephens on 08/06/2012 13:15:51
