Mr Coates sir – you will find that it does make a difference as to whether its a rack or a worm. Or can do, depending on the accuracy you want.
A gear to fit a rack is simply that. A bog standard spur gear cut with a no1 cutter if you are not hobbing, which we amateurs will probably not be.
A wheel engaging in a worm is of a different form, and is normally relieved in the centre to fit “around” the worm.
Actually this is an unusual case of the device being both a form of rack, as well as a worm.
You can use the TDI as a distance travelled indicator, quite nicely for rough setting, when using the handwheel and carriage. When it acts as a rack driving a pinion. Its just a matter of counting whole turns and fractions thereof which are all conveniently marked up- excellent and quick for ruler length measurements.
And for picking up a helix as a conventional TDI, when it acts as a worm driving a wheel.
Edited By mgj on 24/03/2010 18:15:53
