Thread-cutting oil
Thread-cutting oil
Home Forums Beginners questions Thread-cutting oil
Viewing 17 posts - 26 through 42 (of 42 total)
  • #591497
    John Reese
      @johnreese12848
      I use the dark cutting oil of the type plumbers us for threading pipe. It is especially good on gummy steels.
      I know that bacon grease works very well but any left on the machine or the chip pan will go rancid.
      Nigel Graham 2
        @nigelgraham2
        Cleaning out holes by manually blowing: use a length of thin polythene tube – and protect your eyes! I use this for holes drilled into brick or concrete, as well as metal.
        DMP –
        Through-tapping leaving unsightly holes: one approach if the design allows it to use a screw or stud with turned end that ends flush. Or if enough spare depth make a little grub-screw from a bit of studding of the same material, wind it in with a touch of locking-compound then when cured, carefully trim and draw-file to finish. It may leave a thin circle but still neater than a grime-trapping 'ole.
        The metalwork shop in my school was back in "suds" days and the pillar-drill had a supply of that dispensed from a washing-up liquid bottle. I've also used a pump-action oil-can to dispense cutting-fluid on my own bench-drill – though over-enthusiastic pumping can be a bit messy!.
        #591566
        Neil Lickfold
          @neillickfold44316
          I have been using a Blaser oil from Switzerland. It is clear, has almost no smell and is very good for tapping holes and metal cutting in general. I have been using it in my hone, and getting very good stone life, but without that sulphur oil smell in the shop. It is great for drilling holes as well. Work has been using it for over 18 months now with very good results from it as well.
          Edited By Neil Lickfold on 25/03/2022 15:00:34
          Edited By Neil Lickfold on 25/03/2022 15:02:43
          #591569
          Jouke van der Veen
            @joukevanderveen72935
            Blaser is a wel known known company supplying all kinds of cutting (Blasocut) and milling (Blsomill) oils and emulsions worldwide. I remember the Blasocuts from my work. What type of Blaser oil should be used for tapping by hand.
            Above I read about the “Dutch tallow”. I know, not much is blamed to the Dutch on this forum but this needed some research from my side. What I understand now is that it should be called “ditch tallow”. No blame for this mistake because the letters i and u are neighbours (at least on my keyboard). 😉
            #591572
            Jouke van der Veen
              I did some editing on the above text but it appeared not to come through.
              It should be: Blaser is a well known Swiss company. And Blasomill.
              #591578
              Samsaranda
                @samsaranda
                Blaser make excellent shotguns too. Dave W
                #591581
                Jouke van der Veen
                  It’s all in the game.
                  #591585
                  oldvelo
                    @oldvelo
                    Slightly off topic.
                    "" Forgive the slight deviation, but while we're at it I'd be interested to know people's preferred method for dispensing their neat cutting/tapping oil when machining, as long as it is a method that ensures I won't spill the oil on the floor"" .
                    Use a Pump type oil can with a "Pipe Cleaner" shoved in the spout with just a little bit of the tip stuck out to us as a rechargeable brush or to drip the oil from it.
                    You do not need to take your eyes off the job to thrash around to find the spill proof pot and splash fluid everywhere on the return stroke.
                    This has been my preffered method of applying cutting "Neat" fluid and kerosene mix for many years now.
                    As for "Bacon Grease" it's not acceptable as the salt used to cure the bacon is corrosive and when it goes rancid it Stinks.
                    Eric
                    Edited By oldvelo on 25/03/2022 19:00:31
                    Edited By oldvelo on 25/03/2022 19:03:20
                    #591586
                    DMB
                      @dmb
                      Nigel Graham2
                      Thank you for your advice on blocking up through threaded/ drilled holes. May do that eventually but have to wait for time being- priority is to get HH s t& c grinding jig up and running, earning it's keep!
                      John ("Dirty Metal Basher" ) knickname received from one of the tabletop layout brigade who don't like getting their hands dirty.
                      Edited By DMB on 25/03/2022 19:11:28
                      Edited By DMB on 25/03/2022 19:16:13
                      #591605
                      Neil Lickfold
                        @neillickfold44316
                        Posted by Jouke van der Veen on 25/03/2022 16:14:47:
                        I am using the Vascomill CSF35 Neat cutting oil. It is what I am also using in my Delapena hone as well. It's kind on hands for me. When turning or milling I have a small 12mm paint brush that I brush a very light coating onto the surface. With the taps I paint on the oil to the tap itself, and put a drop into the hole to be tapped. When centre drilling or drilling I use the paint brush and just paint the oil onto the drill or the centre drill. It's really good stuff.
                          Is it available in ME amounts or do you have to buy a 20lts drum if you can't bring a small amount home from work?
                          #591625
                          Neil Lickfold
                            @neillickfold44316
                            In NZ it is sold in 500ml bottles as the smallest amount. A 1litre bottle with postage in NZ is $25 from the agents in ChristChurch. https://www.toolingsolutions.co.nz/ Here is the NZ agents. Just email or call them for NZ people. I have no connection to this company. Just a happy user of the Blaser oil. In my shop on the lathe and mill I have used lass than 500ml since I have started using it.
                            #591674
                            Howard Lewis
                              @howardlewis46836
                              I don't seem to suffer corrosion on threads cut using bacon fat. But I clean the job and the Tap or Die afterwards.
                              So maybe cleanlines is next to Godliness.
                              My stock has been in a small stainless steel pot, for several years, and does not seem to gone rancid and stink, yet!
                              By now, the poit and my big tin of Rocoo RTD are both about half used.
                              #591696
                              Bill Phinn
                                @billphinn90025
                                Posted by oldvelo on 25/03/2022 18:54:22:
                                Eric
                                Thanks for the tip, Eric.
                                #591722
                                Alan Johnson 7
                                  @alanjohnson7
                                  Angel's Breath.
                                  MEW Issue 72 (March/April 2001), Page 58, by J. R. Lait, Lincoln.
                                  He said Angel's Breath is ideal for drill and tapping 25BA holes in extremely tough armour plate type alloy.
                                  DMB (above) described it as Guy Lautrard's formula.
                                  It works very well, but you must use genuine turpentine – sometimes called Artist's Turpentine. Smell is pleasant too, and doesn't become rancid.
                                  #591724
                                  Peter G. Shaw
                                    @peterg-shaw75338
                                    I don't consider myself to be a "machinist". Rather I am someone learning by experimenting to see what works. Or does not work as the case may be. What follows then, is as a result of my experimenting and may not be applicable to others.
                                    For steel I use Neatcut which I obtained from Warco some years ago. I did some experimental deep & high rate cutting using tools made from old files: these produced lots of smoke, but the tools did work. However, as a matter of course, I do prefer light cuts so much less smoke.
                                    I also have some Rocol fluid dilutable 1:1 with water. It makes a mess, and leaves a green sticky mess behind. As a result I now only use it for parting off, mainly because it will fill the cut.
                                    For aluminium I use a concoction of oily dregs & paraffin. Proportions, I have no idea but I suspect probably 1:1. It does give a reasonable finish to the ali although I suspect pure paraffin would be just as good.
                                    To apply the fluids I use a small paintbrush dipped into a small container of whatever fluid I'm using. Sometimes, such as parting off, I use a small plastic bottle supplied, I think, by Millers. These have a flexible spout with a sealing end and can inject the fluid into a hole up say 50mm deep. Unfortunately, the Rocal fluid causes the sealing end to seize up and block, so I have had to make a new tube out of brass. Ok, I've lost the flexibility, but at least I can still get the fluid into the cut.
                                    Just to expand slightly: I use Trefolex for threading, and ordinary (presumably) engine oil dregs both on my hacksaw blades (makes hacksawing much easier) and on the drilling machine which does make for easier drilling albeit with a little bit of smoke.
                                    One snag with the Trefolex is that the oily liquid in which the solid compounds are presumably suspended has separated out such that I now have to dip well down to get the solids. Is there any way of recombining the two parts?
                                    Cheers,
                                    Peter G. Shaw
                                    #592732
                                    Ed Duffner
                                      @edduffner79357
                                      There is also a WD-40 cutting oil in a spray can for steels and titanium.
                                      Ed.
