Always try to avoid blind tapped holes like the plague.
I find that there is generally, no need for a blind tapped hole, so ignore drawing, poke tapping drill right through and tap generous depth for what is required, not necessarily all the way through. Good example being the clamp screw mount, part no. 22 and the adjustable fences, part no. 11, both page 99 in Harold Hall' s book, " Milling, a complete course" where he describes in detail the construction of his tool and cutter grinding jig. I drilled the tapping size holes right through. No messing about trying to remove tap swarf from the bottom of a blind hole, just take a large breath, mouth close to hole and blow – HARD! Also no risk of winding tap in too deep and busting it in the work. I either use my special thin oil mix for small holes or Trefolex for larger stuff where it's easier to wash out with paraffin. Don't use any form of sludgy jollop, Trefolex pork dripping,etc., etc in small holes – very difficult to wash out. Downside of what I've done above, is an unsightly hole in the tops of the fences, but does it matter?
Now go to page101, "Swivel Base" Part no. 31, has an M3 blind tapped hole 8mm deep, x4 off. I actually had to do 8 off – 4 wrong edge and 4 correct edge because I failed to check drawing one more time! Boy, did I swear! I thought that my error wouldn't be very obvious by re-doing those holes on the opposite edges rather than re -positioning the 6 off M6 through holes in the top. Point is, 8 blind tapped tiny M3 holes in mild steel and no busted tap. I used the thin oil jollop.
Guy Lautard's recommendation of 1 part Turpentine, not Turps substitute, 2 parts White Spirit, 3 parts Olive Oil. I use a tall narrow Salad cream bottle with a paper measuring strip up the side. Shake well and decant into small plastic squeeze bottle with pouring spout, wife's used hair colouring jollop bottle. This is my favourite concoction for tapping, or just drilling, small holes. Ali and like alloys, paraffin or WD40. Always Trefolex on dies because it's easier to wash out of the dies and off the work. Lastly, don't buy 2nd hand taps and dies – very likely to be blunt, will year rather than cut and taps could snap under the strain.
Edited By DMB on 24/03/2022 09:38:18
Edited By DMB on 24/03/2022 09:41:46
