Whether you cut a 1.75 mm or 2 mm pitch thread, you are cutting a thread which is coarser than the 1.5 mm pitch Leadscrew. This will impose a greater than normal load on the plastic Chagewheels, and probably on the motor. Being an SC2 it will have a brushless motor, and so lack the Hi / Lo gear option of the earlier C2 with brushed motor.
The thread will be fairly deep (1.01735 mm ) so the final cuts will impose quite a load.
I would advocate making up a Mandrel Handle for this kind of work.
It will enable you to deliver the torque needed, without stressing the motor and drive, and you can control the speed, so that it is below the minimum that is possible with powered drive.
(As an aside, the motor will be rotating slowly, whilst delivering a lot of torques, so will not have sufficient air flow for adequate cooling, if the job takes anything other than a short time.
This is not to suggest that the motor will not be reliable, but why risk overheating it?
Also, if the thread runs up a shoulder, a mandrel Handle may very well allow you to stop rotation more accurately than depending on the motor and gear train coming to a halt. You can save damaging the tools that way!
HTH
