Maurice. This might help. I have a copy of the DORMER Technical Handbook, purchased from Greenwoods at the Harrogate Exhb. The book contains vast amounts of information on all sorts of cutting tools. I would agree with one reply the quality of the dies is crucial. I purchased a set of ME dies from a recognised trader and they are poor quality HSS.Some of the dies are OK but several have faults as follows
1) the two dimples set at 90 deg for closing down the die are not in the same plane so when adjusted twist the die and consequently thin the threads.
2) The split in the dies are not symetrical ie the 90 deg 'V' is off centre or not at perpendiculr to the two faces
3) The lead angle on the dies is not sufficient.
DORMERS advise that and appropriate chamfer is applied to the bar to be threaded to form a centralising lead
Good quality dies to BS or similar standards should not be expanded as this causes rubbing.
You might find ( if the dies are of good quality the the lead chamfer is different on one face to the other If so start with the greates lead. This is usually the face with the makers name on it.
Hope this helps
Peter
