On
11 July 2024 at 12:27 S K Said:
Worrying about the rise and fall times of a switching light source is surely irrelevant because the light source won’t be switched on and off in normal use.
But I’ve repeatedly brought up the question of just how good does the timing need to be to be superior to the mechanical noise in a high-performance pendulum? About the best pendulum data I’ve seen is about 1 ppm RMS jitter in short-term period measurements. Now, those measurements were themselves made using break-beam or Hall effect sensors, so one has to be careful, but if 500-600 ps RMS noise in the electronic timing is adequate, then the simple break-beam approach is fine.
Whether a factor is irrelevant or not depends on what the need is!
SK’s query about how good the timing of an individual pendulum swing needs to be is a good example. Not much for ordinary pendulum clock purposes, where the timing and rate are determined by averaging the total of many swings. Averaging hides many sins, but provided errors balance each other out, who cares?
Well I do. My goal is to build a pendulum clock at least as good as a Shortt-synchronome, this to be achieved by exploiting cheap electronic and other modern techniques not available to Mr Shortt! Despite promising results, no coconut so far. The devil is in the detail, and the more accurate a clock needs to be, the more difficult those details become. Things irrelevant to building an ordinarily respectable pendulum clock suddenly become serious roadblocks when 1000x accuracy improvements are required.
One example is errors caused by disturbing the bob. The bob should be protected from draughts in the room, but tightly boxing the pendulum causes turbulence inside the box. How bad is the chaos? Only way to find out is to measure individual swings accurately.
Shortt fixed the turbulence and draught problem by running the synchronome in a vacuum. A good solution, but challenging for me.
The bob is disturbed by many other factors, Shortt found a problem with Invar rods, later found to be because although the alloy has a wonderfully low temperature coefficient of expansion, it is also rather unstable at the molecular level. The instability is so small it needs a highly accurate pendulum to reveal it! Cure: use a particular member of the Invar family that’s least unstable, and age it for a few years before use. My problems are less exotic, notably my dubious build quality, where the construction might be too mobile!
The easiest way to detect bob problems is to measure individual swing times. I’ve detected:
- Bob flying in an ellipse, rather than straight (mostly fixed by levelling, and using a flat spring suspension)
- frequency dropping in jerks due to suspension slippage (design error)
- Over impulsing problems: (set-up error)
- The rod going ‘twang’
- period disturbed unduly
- Ambient light issues (screen required)
- Apparent bob problem actually caused by IR internal reflections (design error, blacken shiny surfaces and add slits.)
- Poor choice of break beam module. (didn’t confirm an assumption)
Current state of play is that my per-swing measurements are telling me loud and clear that something is still wrong. More work needed.
Once my pendulum is beating and being measured satisfactorily I need accurate per swing measurements to calculate the temperature and air-pressure correction coefficients. They depend on accurate statistics, not just averages, of per swing pendulum timings plus long term start-finish data. Garbage in, garbage out – when statistics are being gathered, the data needs to be as good as I can get it, because of the way the I’m tacking the ultra-high accuracy problem. If it sounds unnecessary to other clockmakers, I’m not surprised – as far as I know the Duffer clock is unique. Also unproven!
