Thompstone Engine
Thompstone Engine
Home Forums Stationary engines Thompstone Engine
Viewing 25 posts - 26 through 50 (of 59 total)
  • #587359
    paul rayner
      @paulrayner36054
      Hiya Jason
      Just made a start on this engine at last!
      how difficult is it to silver solder cast iron if I used that for the cylinders?
      bearing in mind i'm a novice.
      thank you for your response in advance
      regards
      Paul
        It is possible but if you have not done much silver soldering before it may not end well. Basically you need to preheat the parts to bring as much carbon to the surface as possible and then wire brush it off. Then flux with HT1 or Tenacity No5 and solder the parts together.
        Another option if you want to use cast iron would be to use JB weld to bond the parts together, you could reduce the number of joints if you made the cylinder and it's flanges from one piece of 40mm nominal CI bar and just stuck the valve & exhaust blocks plus the feet on.
        #587379
        paul rayner
          @paulrayner36054
          How does Jb weld fair with steam?
          I do intend only to run on air but you never know.
          methinks it could be tricky machining the slot for the valve and exhaust blocks with the flanges on.
          mmm.
          #587386
          Nigel Graham 2
            @nigelgraham2
            If by the "slot" you mean the ports, that's not a great problem. In fact you can use the flanges to advantage.
            Engine cylinders like these are normally cast with the flanges in place, and once those are faced parallel with each other, they can be used to align the cylinder on the mill, e.g, between angle-plates, for machining the feet, valve-face, ports and the valve-chest's mounting surface.
            Other builders of similar engines may use a different, valid approach, which is fair, but that's how I'd do it.
            #587390
            paul rayner
              @paulrayner36054
              Hiya Nigel
              I know what you mean, but this cylinder isn't as straight forward as that, The valve flange and the steam passages are in one "T" piece soldered to the side of the cylinder there is a picture of Jasons cylinder halfway down the previous page, or the drawings are in ME vol 226 no 4662 page 491 if you are interested.
              I Think the only way round it would be rather than milling a slot into the cylinder, to mill a 10mm flat on the cylinder, that way I could machine the cylinder, flanges & decorative bands.
              soldering it could be a problem for me though!
              or part with some cash.
              thoughts anyone?
              #587410
                Instead of machining straight along the cylinder with a 10mm bit use a much smaller one, 3mm ideal or 4mm would do. This would leave a radius in the corners as you get to the flanges, just file the corners of the valve block to suit and you will be able to fit the valve block OK. If that is not clear let me know and I'll modify a drawing to show it.
                You could also reduce the width of the 6mm passage slots in the valve block to 5 or even 4mm to get a bit more area for the JBWeld to bond to, just don't use excess and have it oose into the passage and block it.
                As for steam it will be fine, If you have seen any of Ramon's steam launch with a JBWelded twin cylinder block you will see it runs fine and he has also tested JBW joint(cold) to over 500psi.
                #587411
                  Nigel, we are talkning of how to build up the cylinder "casting" in particular the flat along the sid eof teh cylinder where the valve block and passages fit see this drawing
                  This engine like several of mine does not have slotted ports, they are drilled as shown on this drawing
                  Edited By JasonB on 27/02/2022 08:09:20
                  #587426
                  paul rayner
                    @paulrayner36054
                    Thank you Jason, I think I will have a go at soldering some cast iron first.
                    Then maybe it will make up my mind!
                    regards
                    Paul
                    #587443
                    geoff walker 1
                      @geoffwalker1
                      Hi Paul,
                      If you are using cast iron I wouldn't bother with silver soldering.
                      JB weld is great and perfect for your application.
                      Good advice from Jason, leave a small radius at the end of the slots, have a narrower channel, and don't get carried away using to much adhesive.
                      Photo is of a cast iron cylinder I made recently, similar to the thompstone design.
                      Geoff
                      #587459
                      paul rayner
                        @paulrayner36054
                        Jason, Bugger me I've got EF flux! so that wont do, JB it is
                        Geoff, thanks for that, a picture is worth a thousand words as they say.
                        Thinking about it I will try Jason's suggestion, use a smaller end mill and file the corners.
                        Now back to the shed with coffee in handsmiley
                        thank you all
                        regards
                        Paul
                        #587464
                          The reason for suggesting HT5 was that you may be heating for some time and this flux won't get exhausted, it doe snot contain anything that helps it solder CI though it does have something in it so it works on stainless steel.
                          #587472
                          paul rayner
                            @paulrayner36054
                            That's correct, with it being cast iron it will take quite some heat and time to get it to temp.
                            Where as I don't think my EF would cut the mustard.
                            Just out of curiosity I went on CUP's site and notice they have a flux for bronze!
                            regards
                            Paul
                            #620134
                            James Smith 24
                              @jamessmith24
                              Hi Jason
                              I started building this engine as a first project and really enjoying it so far. The instructions and drawings are really helpful to me as a beginner, but I am stuck on one point.
                              On the eccentric strap the drawings show a 2mm hole, to join the two halves together, but the material list does not show M2 nuts of sufficient quantiy, and looking at the pictures of your finished engine it looks like you have used a bolt with nut and locknut. Can you enligten me as to what you used and the correct size.
                              Thanks
                              James
                              Edited By James Smith 24 on 07/11/2022 20:45:03
                              #620152
                                I'm just off out but will get back to you later today.
                                #620165
                                John Rutzen
                                  @johnrutzen76569
                                  Hi Jason, lovely photos and very interesting , especially for someone like me who fabricates nearly everything. I hadn't considered JB welding cast iron together for a cylinder. Does it stand the heating/cooling cycles and the moisture? Also , I'm pretty sure that you can silver solder cast iron though I haven't tried it.
                                  #620270
                                    James, having refreshed my mind by taking a look at the finished engine it looks like the bill of materials is wrong and that I have the nuts and the two bolts listed as M2.5 rather than M2.
                                    But I also notice that in my text I said to thread one half M2 and the other half to be drilled M2 clearance.
                                    So there are a couple of options:
                                    -You could tap one half M2 and then use some of the 2mm studding material to make studs and then you would just need two M2 nuts.
                                    – As above but with nuts and locknuts
                                    – Do as I did and drill both halves 2mm for M2 clearance, use a 10mm long M2 hex head screw or bolt and retain that with a nut and locknut. Note Photo 54 in the article shows cap head screws and a nut which were just use during construction.
                                    – You could also drill through both M2 clearance and make up a couple of M2 studs and retain these with a nut at each end.
                                    I hope this error won't set you back too much and please post some images of your build.
                                    #620271
                                      John the JB Weld was an option for those that may not have the facility to silver solder but yes it is possible to silver solder CI, usually needs a pre heat to bring the carbon to the surface which is then cleaned with a fine wire brush before heating again and soldering.
                                      Although my own engines that have been bonded with JBW have only been run on air others here such as Ramon have built engines that do get steamed and have had no problems. Ramon has also tested joints to several 100psi both hot and cold and they hold up well. Do make sure to use the "original formula" (red and black tubes) not the rapid or marine as they don't have such a high temperature rating
                                      #620297
                                      James Smith 24
                                        @jamessmith24
                                        Jason,
                                        Thanks for the comprehensive reply, I had drilled the holes 2mm as the drawing so will probably go with the M2 studs with a nut at each end.
                                        Below are a couple of pictures of where I am up to, I am not totally happy with some of the parts so may yet remake but will see. It has been an interesting project and have learned a great deal from it.
                                        James
                                        #620298
                                        John Rutzen
                                          @johnrutzen76569
                                          Thanks Jason, that's interesting to consider as an option. The design of the joint would also obviously have a lot to do with it. I've only ever used it to make fillets when I fabricated the flywheel for my Rumely tractor.
                                          #620338
                                            That's looking good James and you don't look to have too many bits left to make.
                                            #633061
                                            James Smith 24
                                              @jamessmith24
                                              Finally completed my version of the engine so thought I would upload a couple of photos.
                                              I repositioned the steam inlet so I could recess the valve cover.
                                              #633073
                                                That looks to have turned out rather well, the slightly larger flywheel does not look out of place and the colour is nice and subtle plus it makes a change from the usual dark greens and crimsons.
                                                How does it run?
                                                #633110
                                                James Smith 24
                                                  @jamessmith24
                                                  Thanks Jason,
                                                  I was inspired by your use of muted colours for my choice.
                                                  The flywheel was not ideal, but what I could get hold of reasonably easily at the time, I don't think it looks too bad, but when I compare with yours I do like the slimmer smaller design.
                                                  It runs okay, though have only been able to try on air.
                                                  I have to decide on a next project now !
                                                  #633128
                                                  Dave Wootton
                                                    @davewootton
                                                    Nice work James a very good job and the flywheel looks fine to me, the grey colour suits it well. good luck with the next project i'm sure it will turn out as well as this one has.
                                                    Edited By Dave Wootton on 12/02/2023 13:23:41
                                                    #633315
                                                    paul rayner
                                                      @paulrayner36054
                                                      Hi James Love the colour.
                                                      As it happens I've just pulled out my bits this weekend, hopefully I should get some time over the next couple of weeks to do a bit more.
                                                      Paul
                                                    Home Forums Stationary engines Topics
