Home › Forums › Model Engineer & Workshop › This months MEW are 3 CNC features two too many
Well, from John Stevenson’s post I can see why he is interested in CNC articles and I do not dispute the number of CNC machines out there. This must support the view that a separate magazine dedicated to CNC is required.
John also raises the interesting point that early editions of MEW had 15 project subjects per edition and this has now dropped to 10!!
From a personal viewpoint I have no engineering background and started to teach myself around the time MEW first started. So working on the oft quoted basis that you can teach a good engineer to use CNC but can’t easily teach a CNC operative to be a good engineer I feel it will be many years before I can convert to CNC. I am fully in favour of articles on a wide range of engineering subject but believe they should be comprehendible and contain some general engineering information.
Edited By NJH on 31/05/2011 15:36:45
TerryD
Jim
Edited By Jim Nolan on 01/06/2011 07:46:23
Edited By Jim Nolan on 01/06/2011 07:47:57
Edited By EtheAv8r on 01/06/2011 10:03:39
Posted by John Coates on 31/05/2011 21:07:21:
Edited By Tony Jeffree on 01/06/2011 11:08:44
Tony
My last MEW on subscription was issue 164 and I have not regretted that decision – keeping my eye on what is in each issue on this site, and in Smiths, and picking up outdated issues for a quid or 50p. I do not normally participate in these discussions , but I have to add to what is being said. I am prompted to post by the posting from some chap mentioning that it was his decision to stop subscribing that was the one mentioned in issue 165 Page 61 “Reasons not to Subscribe 1”, And I thought that was me! Unfortunately I cannot locate that posting in this thread – it may have been deleted as being a touch embarrassing!
It amazes me that the Editor has not terminated this thread long ago – he would have done if he had been around at the start of it instead of at Harrogate. He must hate it and hope it goes away with the next issue. I have met him on his two visits to the (most recent) spring Myford open days. I told him (by e-mail at the time) by way of explanation as to why I was not renewing my subscription – not least because I could get no responses to my offer of articles or (mainly) Scribe a Line. Ironically he used my Scribe a Line offering from my same mailing telling him why I was terminating my subscription in issue 169 (I think) “Light short circuit”, which I thought a real stab in the back.
I seem to have deleted my e-mail to DC ending my subscription; otherwise I would just attach it here, but I generate a similar version as follows: I should add that a secondary reason was the endless Linton Wedlock thing on that drawing program, which ran to at least a full edition and was totally OTT.
I have been in automation all my life, working first at the North Staffs Tech (now a pseudo university), then at Harwell for a few years and all the rest with various versions of GEC which ended up in french hands. In later years it has all been on-site automation on power stations/substations and steel works: central data loggers, sequence and remote terminal controls. anything from humble pumps to Olympus Engines, main boilers and turbines – the lot. I knew/know many programming codes, both complex source codes and basic machine codes. They are good for things you need to do more than once or you are otherwise into manufacturing. They are useless for one-off production as in building a model unless (my example to DC) I wanted to make lots of spokes for Traction Engine wheels. As a fact, I know that it would take me far longer to set up a lathe or mill for one -off’s using CNC than just do the job manually, a unique application being the cutting of spokes in a wheel from solid which is why ArcEuro use it by way of example on their show demo’s. It looks impressive and is a sort of 3D item cutting in two dimensions, needing no datum start point as such beyond the middle of the uncut lump. Some of the postings on this thread infer or state that individuals have gone down the CNC path, “I modified my S7 but am disappointed with my progress”, and are now realising their error.
I am not against CAD/CAM/CNC articles as such, but since the normal mortal making one-off models has to be the main reader of ME/MEW, then it should be restricted. I suspect DC was given the Editorial job as he offered to take MEW forward on a CAD/CAM path, and I suspect Dave Fenner (come back Dave) gave up the job because he could not see enough meaningful content to support more issues per year. I made the following observations to DC, most likely in a different order:
1) If he has insufficient meaningful content, he should not have (agreed to go to) gone to more issues. ME is not like MEW. There is always a different model to serialise in ME – infinitely more variatons on a theme. With MEW a lathe is still a lathe in a literal sense and all we get is variations on a theme and there is a lot less meaningful content per month than there used to be, as others have poined out.
2) He has insufficient content for Scribe a Line because it is all appearing on the web site. Instead of appealing for content he or his assistants should be routing articles to Scribe a Line with permission of the writers at the start of a thread. I always read all the scribes therein.
3) Being Editor of both magazines is clearly one too many and many aspects are suffering. As an added bit not said at the time he claims that the Eds Bench (such as it is these days) is the last thing he writes yet he manages to advertise the Myford open days a month late. Subscribers may just have got it in time.
4) If he dares to, run a questionaire on how many people have gone down the CNC path and given up on it and why.
5) It takes time to master any programming language and even longer to get good at it, and stay abreast of updates and debugs. And you have to be using it all the time or you go rusty! I never make the same item twice, but I do remake bits when I get it wrong. If I went CNC now I would have more failed bits due to my CNC errors. Yes you can cut air and wood first (thus taking even longer) and save all the segments of code for use again, but that is like saving every bit of scrap metal in the hope that it will be handy some day, and how many of us have an ever growing scraps pile.
6) If he wants to go down a CNC path, then he should go off and start a new mag just for CNC.
7) I have no idea how many bullet points I made and this getting a bit long……
He failed to grasp the intention of the “adaptor piece” on the basic holder which is the pre-Whetren adaptor/fitment piece. Kirk at Hemingway would have agreed to it of course because it may sell a few kits although the article did not praise the kit presentation, which I consider unfair.
Thats it
Dennis Rushton
Edited By Tony Jeffree on 02/06/2011 07:09:07
Tony
Dear David,
A few separate rants and then I am gone, likely permanently (some of which you must be aware of);
Home › Forums › Model Engineer & Workshop › Topics
Started by: petro1head
in: General Questions
Julie Ann
Started by:
in: The Tea Room
Started by: Nigel Graham 2
in: Manual machine tools
Started by:
in: The Tea Room
Started by:
Russell Eberhardt
in: CAD – Technical drawing & design
Russell Eberhardt
Started by: Tony Watson 3
in: Model Engineer & Workshop
Started by:
Grindstone Cowboy
Charles Lamont
Started by:
in: The Tea Room
Fulmen
in: Exhibitions, Shows and Club Events
Meridienne Exhibitions 1
Started by:
in: Workshop Tools and Tooling
Vic
Started by: Peter Simpson 3
in: Beginners questions
Martin Johnson 1
Started by:
in: The Tea Room
John Hinkley
Nigel Graham 2
Started by:
Steve Huckins
Howard Lewis
Started by: dbs88
in: Model Engineer.
dbs88
Started by: David Ambrose
in: Model Engineer.
Started by: bricky
in: Help and Assistance! (Offered or Wanted)
bricky
Started by: Dalboy
Dalboy
Started by: martin haysom
simondavies3
Started by: modmechengine1333
Grindstone Cowboy
Started by: Joseph Noci 1
in: Website Questions, Comments, and Suggestions
James A
Started by:
Barry Smith 4
not done it yet
Started by: James A
Bo’sun
Started by: ega
ega
Started by: Speedy Builder5
John P
