Jason I cant push it up a bit my problem insert text after inserting a image is with my laptop I hit the return key and the cursor can not be seen
Ive just tried inserting a small image 200×200 and as you can see it’s not inserted it’s self under some of my text rather than below, so I,m now wondering if my problem is down to ‘wrap’ is it possible to adjust the ‘wrap’ and if so how ?
H
Harry, Please accept my apologies for misleading you regarding the re-sizing and inserting of fixed image sizes.
Last time I tried it, I couldn’t re-size within the compose pane, but it now works.
Similarly as you’ve spotted, you can now insert an image within a section of text, but it looks like it’s only that one line, where the cursor sits, which word wraps.
I’m still playing, but it looks like when you change the width of a window, either by dragging it narrower on a monitor, or viewing on a phone/tablet, the forum might display a re-sized image automatically, according to the display window size.
Also, in order to leave the text readable, as a window width changes, then the text wrapping adapts to the display window size. i.e. two lines of text in a widescreen window may become four as the window narrows.
This does seem to have an effect on the positioning of the image, as it’s tied to where the cursor was in the line of text, so as the word-wrap changes, so does the image position.
Compare the image in your quoted text above, the original posting, and this screenshot, where I’ve split the screen, which effectively narrows the display window.
It’s now moved to the very right hand side.
Note also, that in your original post, it’s the top of the image with the word wrapping, but in the edit pane, even in your quoted post, it’s the bottom of the image with word wrapping
