this is the worst site possible
Home Forums Website Questions, Comments, and Suggestions this is the worst site possible
Viewing 25 posts - 126 through 150 (of 298 total)
  • #703887
      IMG_9193IMG_9194
        … and a slightly better illustration of the user-experience:
        Perfectly legible and uncluttered once you have scrolled through all the ###p
        IMG_9195
        A major failing of this site still seems to be that there is no consistent interface across different devices.
        David Ambrose
          @davidambrose86182
          I’m now seeing the Morton’s pop-op instead of the Warco one, but it still takes me to advintage.net when I click on it on my iPad.  And it is still just as annoying.
          #703949
            Thought I would try clicking the banner Ad David, I think they have lost the plot as this is what comes up. I’ve pointed out what the cause is previously but nothing done about it.
            subscribe 404
            #703956
              Login problem test post.  Seems OK.
              Edit – except for an odd flash – try again.
              #703964
                No wonder the site sucks, there is one with a v in it too
                sucks
                #703984
                S K
                  @sk20060
                  It’s sped up a little, recently, and at least the “click on all the motorcycles” BS is on hiatus, but the latest hilarity is that “accept cookies, etc” nuisance thing.
                  Hit “Reject all” and … nothing happens, can’t proceed! Doesn’t work!? Must I accept? Ah, you can “accept all” perfectly well, and that seems to be about the only way to get past it? 🙄 Well, I fixed that by a bit of script magic that made this “Thou Shalt Not Pass!” test go away completely.
                  Anyway, the cohort of participants whose discussions I used to come here for have all moved elsewhere since the near-fatal collapse of this forum, so I doubt I’ll be back much more either. It’s sad, as I enjoyed my time here.
                  Thanks and good luck to those who remain.
                  #703995
                  peak4
                    @peak4
                    sucks
                    I’ve just been having a quick check to see if I could find those URL mis-spellings, but can’t spot them anywhere now; Have they been mended or is it a cache issue?
                    There does seem to be rather a lot of different links and buttons to that specific URL though; I think I’ve found 14 different ones all on the site’s top page.
                    None of which actually take you to the Classic Magazines subscription page; I do appreciate that this site covers two magazines, unlike Model Boats, where the same buttons do  take you directly to the actual Classic Magazines subscription page.
                    Another odd one, If you actually do visit that “subscribe” URL, rather than the header page, The panel circled in lime green is a hyperlink to where you are already, but the “advert” one circled in pink, tells you how to advertise in Model Boats, not ME/MEW; the main page advert, about advertising here, seems to be more as you might expect.
                    image_2024-01-03_175746580
                    Bill
                    #704007
                    peak4
                      @peak4
                      On S K Said:
                      I………………. but the latest hilarity is that “accept cookies, etc” nuisance thing.
                      I managed to get that to work OK for me on Windows10/Opera browser
                      Have a look at This Post
                      Post 702209 if the link fails
                      Bill
                      #704017
                        I believe they have altered the typo in the url.
                        Have pointed out the Model Boats advert problem too along with another wrong link I found on the lego page as ” new forum here” doe snot take you to the forum.
                        #704033
                        Kiwi Bloke
                          @kiwibloke62605
                          All this discussion about adverts puzzles me. With the most basic advert blocking methods, this is what I see:
                          Screenshot_2024-01-04_08-12-58
                          #704040
                          Kiwi Bloke
                            @kiwibloke62605
                            Bother! Couldn’t add text below image. S’pose I should have reserved a blank line or two, after dropping the pic above them…
                            Using Firefox (slightly tweaked) on Linux, I’ve signed in with only model-engineer.co.uk, gstatic.com, and google.com scripts allowed. The last is required for the apparently pointless reCAPTCHA box to be ticked, no ‘puzzle’ displayed. All cross-site cookies are blocked. The adblocker is currently blocking 10 adverts – Hooray!
                            So it should be possible to change some settings to alleviate some of the complaints above. Perhaps…
                            #704079
                            Harry Wilkes
                              @harrywilkes58467
                              I too was wondering what the talk about adverts was about as I’ve mentioned I use Brave so I thought I’d take a look and this is what I could see on my tablet it filled the whole screen and I couldn’t reduce it.
                              Once again not being allowed to add image to text will try below
                              H
                              #704085
                              Harry Wilkes
                                @harrywilkes58467
                                Screenshot_20240103_213230_Samsung Internet
                                #704147
                                  Well all I can say is as the adverts are the only real income for Morton from the forum, if you all start blocking the adverts you will have more to complain about when they decide to shut the forum down.
                                  Also makes me wonder if help and advice should be offered to those using ad blockers, for example I could tell Kiwi and Harry how they can easily get the text after inserting an image but should I?
                                  Then again it may be because your ad blocker is mucking something up, text here after the image with No ad blocking software No problem
                                  sucks
                                  It works without ad blocking.
                                  #704178
                                    Jason,
                                    Speaking for myself: __ Although I don’t use an ad-blocker on the iPad, I still find it impractical [perhaps impossible] to insert text after an image.
                                    This is probably because I just insert images at whatever size they happen to be
                                    [the forum offers that capability, so why not use it]
                                    Unfortunately, a large image will then ‘swamp’ the editing pane
                                    I therefore insert images into the text when I have finished writing.
                                    dhendley
                                    Keymaster
                                      @dhendley
                                      Warco have a new offer/advert starting today so you’ll see that later. Their Christmas offer ended at Christmas.
                                      #704194
                                        Michael you don’t need to see anything I often insert images and the right side is beyond the boundry of the editing box, just a case of knowing what to do which I have previously mentioned somewhere on here. bent wire thread is a good example the wider third image was beyond the reply box but no problem adding text after it.
                                        #704201
                                          Thanks, Jason
                                          … maybe I am just too old/daft/clumsy/whatever …
                                          or maybe it’s one of those [all too many] things that seem to  work a little differently on various devices.
                                          I have found my work-around, and I can cope with the relatively minor inconvenience of that …
                                            Whoopee !
                                            Easter Bunnies, and Chicks
                                            Harry Wilkes
                                              @harrywilkes58467
                                              sucks
                                              Jason I don’t use a add blocker as such the Brave browser by its nature does it and other features to that’s why I use it. You say you could easily tell myself and Kiwi how to add text after inserting an image but then say ‘should I’ as a moderator I would suggest that if your protecting the interests of Mortons maybe not its up to you where to draw the line, as a forum member I would say yes you should is it not why we are members of the forum to both seek and share our knowledge !
                                              Finally I am surprised that you would make such a statement.
                                              H
                                              #704237
                                                For Harry & Jason
                                                I think this illustrates the problem when composing on the iPad
                                                IMG_9198
                                                Nicholas Farr
                                                  @nicholasfarr14254
                                                  Hi, after inserting an image,
                                                  IMG_20240103_114332
                                                  just tap the return button, and carry on typing your text, as the curser will be on the right hand side of the image, and by using the return will put a space between your image and the new line of text.
                                                  I normally use my laptop when making replies, but I did this one on my Android phone, just to see if it was easy enough for me to do, and I had no problems.
                                                  Regards Nick.
                                                  #704252
                                                    Test
                                                    20230927_130041_OriginalNew line after
                                                    #704258
                                                      There you go, as I hardly ever use an ipad it took me longer to work out how to find and paste the image on the borrowed ipad than it did to put the text after it.
                                                      After inserting the image I just pushed it up a bit with my finger so I could see “white” space below, tapped my finger on that and typed. Simples
