This guy made his own motor bike –
Home Forums The Tea Room This guy made his own motor bike –
Viewing 21 posts - 1 through 21 (of 21 total)
  • #289164
    Steve Withnell
      @stevewithnell34426
      Nice V twin and sounds well
      A proper build!
      Steve
      Steve Withnell
        @stevewithnell34426
        #289175
        AJW
          @ajw
          Nice project!
          Alan
          #289177
          John Stevenson 1
            @johnstevenson1
            This is what you call home made wink
            1948 Jones 250cc twin DOHC, Max revs 11,000 in 1948 but we used to keep them down to 9,000
            At least it's a good use for Myford change wheels [ Actually they are all in steel except the mag wheel in alloy but they were made at Myfords.
            Edited By John Stevenson on 16/03/2017 23:05:00
            #289178
            Bill Pudney
              @billpudney37759
              Now, THAT'S a gear train!!
              cheers
              Bill
              #289183
              duncan webster 1
                @duncanwebster1
                If you go to
                There are quite a few home made V twins, the best to me is 2 Venom cylinders on one crankcase. No you can't make it on an ML7
                #289189
                RichardN
                  @richardn
                  Or what about using a couple of Pratt and Witney cylinders from a radial to create a 5 litre V-twin on a custom cast crankcase…?
                  She sounds lovely and gently burbles after a thump on the kickstart… this guy has made too many bikes from 'interesting' engines…
                  #289191
                  Chris Evans 6
                    @chrisevans6
                    Duncan, probably me or my lack of computer skills but the link only shows text and no pictures. I was interested in the Vee twin Velo I think it could be a local bike to me. Built by a member of my VMCC branch, is the bike on the link painted in green ? Chris.
                    #289194
                      Good board tracker "build thread" here for those that want to make one, or a simpler single cyl bike to a 1906 design here
                      #289205
                        Posted by Chris Evans 6 on 17/03/2017 07:29:15:
                        I've just tried Duncan's link on the iPad
                        … It takes a couple of seconds to load the page, but seems fine.
                        MichaelG
                        #289209
                        duncan webster 1
                          @duncanwebster1
                          Posted by Michael Gilligan on 17/03/2017 09:09:55:
                          MichaelG
                          Link works for me, here it is longhand
                          http://www.diagnosis2012.co.uk/vtwininnovators2.html
                          the velo is green, called 'vulcan'
                          #289220
                          Hopper
                            @hopper
                            Posted by John Stevenson on 16/03/2017 23:03:19:
                            If it was anyting like the gear-driven cams on my VFR800 Honda, that lot should have made a most glorious whining noise as the engine was spooled up.
                            #289235
                            Chris Evans 6
                              @chrisevans6
                              Duncan, that is the Velo I know. Belongs to a VMCC club member, sounds lovely when out on a run.
                              #289242
                              Mike Poole
                                @mikepoole82104
                                #289260
                                duncan webster 1
                                  @duncanwebster1
                                  Nah, that's two engines coupled together, you can only count that if this
                                  is a square 4
                                  #289265
                                  Mike Poole
                                    @mikepoole82104
                                    It was built on a custom crankcase but it is as you say a coupled engine but so was an Ariel square four and an RG500.
                                    #289297
                                    John Stevenson 1
                                      @johnstevenson1
                                      Posted by JasonB on 17/03/2017 07:36:54:
                                      That link posted by Jason is a good one but doesn't tell the whole story.
                                      When he first started blogging about this it made me wonder just where it was going, a lot of work for a static exhibit but then when he's sorted all the design out and realised what problems he might have and how to over come them, the builder, Paul Brodie then announce he was doing a limited production run on these bikes.
                                      From what I can gather he's built 6 so far, all have sold for well over a quarter of a million dollars each and taken just over a year to build.
                                      If we put that into the context of building a model which is probably over a longer period but not full time and you then take the value of that model, there is a massive difference but many even on this forum have the machinery and skills to build something like this IF you can spot the niche market.
                                      Not bad retiring with one and a half million as opposed to selling a choo choo for 10k max ?
                                      Oopps forgot the link.
                                      http://flashbackfab.com/excelsior-homepage/
                                      Edited By John Stevenson on 17/03/2017 23:52:14
                                      #289307
                                      thaiguzzi
                                        @thaiguzzi
                                        Posted by Mike Poole on 17/03/2017 13:51:15:
                                        Scary!
                                        #289308
                                        thaiguzzi
                                          @thaiguzzi
                                          Posted by duncan webster on 17/03/2017 01:29:36:
                                          If you go to
                                          Er, i'm no elf 'n safety nut, but no way am i riding a chain driven OHC motor with external chains whirring about near my 'nads…
                                          #289309
                                          thaiguzzi
                                            @thaiguzzi
                                            Posted by John Stevenson on 17/03/2017 23:51:07:
                                            Classy!
                                            Had to read the whole lot. Very enjoyable.
                                            #289341
                                            Ian S C
                                              @iansc
                                              One bloke here built quite a nice V twin, well ten actually, that was John Britten, his own design and build of engine and gear box, and his own ideas of how a bike should be built, including using the engine as the frame. Sadly John died of cancer, and his dreams died with him, but his bikes are in collections and museums all over the world. The only one I'v seen lately was at Te Papa museum in Wellington (NZ). John was an artist as well as an engineer.
                                              Back in the early 90s a 1:12 scale die cast model was produced at $(NZ)300, it was a very limited run so I don't know what ity would be worth now. For the real thing today, you would be lucky to get one for anything short of a million.
                                              Ian S C
                                              Edited By Ian S C on 18/03/2017 11:23:37
