Things we should not do
Home Forums General Questions Things we should not do
Viewing 7 posts - 51 through 57 (of 57 total)
  • #66224
    Hugh Gilhespie
      @hughgilhespie56163
      From recent experience.
      Wear really good face protection and strong when changing the blade on a band saw.
      If you get swarf in your eye, go straight to hospital. If you leave it you have the extra delight of ‘rust rings’ that also have to be (painfully) removed.
      Hugh Gilhespie
        @hughgilhespie56163
        Oops!
        Wear really good face protection and strong gloves when changing the blade on a band saw.
        #66227
        Stovepipe
          @stovepipe
          Posted by John Stevenson on 28/03/2011 14:35:10:
          It’s actually RTFM
          Read The Flipping Manual
          John S.
          Thanks, John. I meant to type RTFM, but obviously I’m one letter short of an acronym !
           Yes, Diane – so I did type it correctly, before being “blitzed”, sorry, “moderated” !
          Dennis
          Edited By Stovepipe on 28/03/2011 19:00:11
          #66229
          Richard Marks
            @richardmarks80868
            Steve
            I was talking about an incident that happened over 30 years ago, and I now do exactly as you do, you cant see or smell electricity but you can certainly feel it, that also goes for hydraulics and pneumatics, immense power stored in a small place ready to trap the unwary or stupid.
            Dick
            #66231
            RJW
              @rjw
              Don’t get complacent, and Never Ever take your eyes off any moving machinery for a second – especially cutting blades!
              And, If you don’t need the machine running if you need to move something, Turn it Off!
              I speak from scary and very painful recent personal experience.
              Having ripped down a couple of dozen chestnut spindle blanks on a 12″ 3HP table saw, I moved round to the side of the table to pick off the final new blank.
              Catching some movement in my peripheral vision, i looked up – it was my wife walking past the open barn door!
              For whatever reason (complacency? borne of doing this kind of work for a few decades maybe? ) I carried on picking up the spindle blank and Not Looking where my hand was going – which was actually well to one side of where the blank was sitting!
              Unfortunately, and God only knows how it happened, because I don’t, I shoved my right hand straight into the top side of the 12″ TCT cutting blade, which was running at around 3000 RPM.
              All I remember of the immediate incident, was a bang and my arm being thrown back behind me, plus a mist of blood spraying everywhere! (which is also unfortunately, what my wife saw)
              Fortunately the saw guards were down, but the wide kerf on the blade tips had chewed into the end of my right thumb from underneath and up into the nail, from the right nail root to the left side of the tip, bouncing off the bone.
              All that was left of the tip was a chunk of nail hanging onto a bit of flesh.
              I can tell you it was Not a very pleasant sight at all, quite frightening in fact, and the pain was absolutely bloody unbearable for some time!
              I got through a Lot of paracodol that first week!.
              I can no longer feel anything in that thumb tip, and picking up anything small is now difficult, which has virtually screwed me on watch repairs, But, you wouldn’t even know I’d pulled that stupid stunt just by looking at the damage.
              I do know I was Very damned lucky not to have lost a lot more than I did!.
              The lesson driven home to me, was that although I’m always very careful with these things (push-sticks always used, hands behind and well clear of the blade, guards in place etc) I didn’t Need the saw running at all when that accident happened!
              RJW
                @rjw
                One incident I recall from my motor engineering days, prompted by the ‘high pressure in small volumes’ comments.
                A
                couple of apprentices were pratting around in the lube bay one day,
                with one berk firing off the air powered grease gun at his chum!
                Firing this thing off into open air, would send a fine jet of grease a good 20ft!
                Unfortunately, he got a bit too close for comfort on one
                shot, and the high pressure jet of grease caught the other lad’s finger
                slitting it wide open, stuffing a good wodge of the stuff under
                the skin where it was ruptured!
                Immediate hospital treatment needed due to lithium grease getting well embedded in his flesh.
                That wound looked very untidy for quite some time!
                Edited By RJW on 28/03/2011 21:00:45
                Edited By RJW on 28/03/2011 21:01:13
                #66264
                Nobby
                  @nobby
                  Hi
                  Dont leave the chuck key in the chuck.
                  With screwed on chucks dont switch into reverse to stop the lathe.
                  Dont climb mill on a conventional milling machine
                  ITs been said before dont use a file without an handle.
                  Always clamp job on drilling M/C
                  Dont pull swarf with fingers.
                  Set stop on flypress and you wont hit yourself
                  Regards Nobby
