Hi, all.
I'm trying to source some steel to make a watch dial. The dial will be about 37mm across and wants to be between 0.4 and 0.5mm thick.
I've actually ordered a couple of bits in from eBay (one stainless and one mild), but neither were flat and the mild looked like it had been at the wrong end of a boxing match!
From what I can make out flattening steel sheet is far from trivial so best if it came flat.
I was also struggling to cut it without stressing the edges. Shears will almost certainly bend it, bandsaw really needs several bunched together. Dremel will probably work OK, but the attempt was the last gasp for my poor old dremel so I've another (cheap knockoff) coming.
My closest to success isn't too bad, though my attempts at pressure turning clearly need some practice! The dial will have a 2.5mm hole in the middle which will help.
So a few questions :-
where can I get stock (cheaply, of course) which will arrive flat (within 0.05mm say over my 40mm area)?
Can I flatten it to that level if it doesn't (with basic tools)?
Any suggestions on how I can cut it into squares (or polygons) before cutting to final size (Probably with pressure turning)?
Any advice would be much appreciated!
Iain
