thick wall steel pipe for rollers
Home Forums Workshop Techniques thick wall steel pipe for rollers
  • #148054
    capnahab
      @capnahab
      I need to move my lathe in the workshop. I have been using short lengths of 1 inch mild steel bar. I would like something longer ( 3-4 foot) and have seen people use thick walled tubing, – could be the rigid compressed air stuff ?. Does anyone have any recommendations ?.
      capnahab
        @capnahab
        #148055
        Mark C
          @markc
          Scaffold tube, cheap easily found
          Mark
          #148056
          capnahab
            @capnahab
            Scaffold tube is good but a bit big on the diameter , for various reasons needs to be about an inch.
            #148057
            Rick Kirkland 1
              @rickkirkland1
              25mm dia electrical conduit. Cheaper than steam pipe and up to the job.
              Rick
              #148062
                3/4 Gas Barrel wil have a thicker wall than coduit and being the 3/4" is the bore then the OD is about 1 1 /16"
                #148069
                Brian Wood
                  @brianwood45127
                  What about plain galvanised water pipe, nominal 1/2 inch bore? Also cheap and available
                  #148070
                  Paul Lousick
                    @paullousick59116
                    Why not water pipe ? Cheap from local hardware shop or cheaper from a scrap metal agent
                    #148083
                    Gordon W
                      @gordonw
                      If you can get them- 2 sheets of steel with grease between, easier and safer. Good ply etc. also works.
                      #148087
                      Bazyle
                        @bazyle
                        Usefull pointer to the use of 3/4 pipe as I have been ruluctant to cut down my 5 ft scaff pipes to 2 ft to get though gaps.
                        It may be worth looking at the underside of your machine to see what the shape is. While the feet may present a flat wide load area if the roller moves along under a thin steel cabinet wall for example the pressure distribution may be bad for both the cabinet and roller. If that is ok then short 6 in lengths may be easier to move about and cheaper too. Since thin rollers are affected more by grit and concrete roughness shorter ones may reduce that problem.
                        #148089
                        Ed Duffner
                          @edduffner79357
                          A few tool and plant hire shops offer skates to place under machinery / appliances for moving around.
