The point of this is a 'project' for taking the Dremel 3040 3D printer through its paces for review, so not just links but sprockets, suspension links and road wheels as well.
Posted by Ed Duffner on 31/12/2016 13:45:52:
I join the 35th scale metal track links(Friul Model) on my tanks with a thin piece of wire and CA glue. Plant myself in front of the TV or Youtube and work away.
With a 3D printer I thought it was posible to print the whole thing in one go, including the joints?
Exactly what I'm doing. An all plastic joint might not be strong enough at 1:6 scale, and you can't print close joints.
An alternative would have been clip-together links, but a challenge to make these robust enough and what clips together can unclip….
> I've no idea what you are making but suspect I would be thinking of a redesign that didn't need so many pieces.
The problem is that the links have no flat surfaces large enough to use as the base of a link. Taking off the 'tread' leaves a flat surface with plenty of adhesion and minimal overhangs. I could use them like this, but gluing on a gull-wing makes them pretty realistic. The problem is that the treads being only 1mm thick and tapered at the ends (to simulate a bit of road-wear) tend to curl a little and need to be held in place while the glue dries. Unworn treads would not have had this problem, but I've started so I'll finish…
I must admit, I have no idea why some people get one then can't think of anything to do with it. I.
