Hi Moose
The sizes, I gave were from the drawings of Wyvern. It occurs to me, that when Westbury designed the engine, gas meant, town or coal-gas; so the drill size may not be suitable for butane.
Wyvern was the first I I/C engine, I built, 30 odd years ago, but I cannot recall what drill size I used.
For your info, all of my 17 engines, run on butane. All need only, a whiff of gas. I use a micro-valve in the line. Starting problems are invariably linked to, too much gas, rather than too little. However, this should be no problem, if you are using petrol.
Jim
