The ultimate project?
Home Forums The Tea Room The ultimate project?
  • #36698
    Farmboy
      @farmboy
      Farmboy
        @farmboy
        Just in case I'm not the only one who hasn't seen it before . . .
        The Do Nothing Machine
        It just popped up when I was browsing earlier. Looks like something I might have made if I had more free time teeth 2
        #579052
        alan ord 2
          @alanord2
          If you like cutting gears, this is the project for you. First time I have seen a square gear!!!!!!
          Alan.
          #579060
          Nigel Graham 2
            @nigelgraham2
            Magnificent!
            It's worth bearing (oops) in mind that all those mechanisms individually do have real uses.
            Even things like that elliptical gear – an example of many solutions for applications needing variable-velocity ratios and the like.
