The repair shop
The repair shop
Home Forums The Tea Room The repair shop
Viewing 7 posts - 26 through 32 (of 32 total)
  • #498992
    Nick Clarke 3
      @nickclarke3
      Posted by Speedy Builder5 on 01/10/2020 06:45:22:
      Yes, agree with all the above, but why does Susie (Leather worker ?) use this glue ? HOWSTICK 125.
      leather glue
      The manufacturers say it is for temporary holding of leather ??
      Edited By Speedy Builder5 on 01/10/2020 06:46:10d
      I suppose it is the difference between a professional craftsperson an an amateur like myself.
      I look at the manufacturer's spec and use what they recommend, while a professional uses what they know from experience will do what they want it to do.
      Packmule
        @packmule
        Jim Young 2.
        The use of staples on antique items is a real ‘no no’, if it is tacked when stripped then tacks it is when it goes back!
        As a upholsterer of over 50yrs I have to disagree with your statement. I understand its not original but had staple guns been around then they would most certainly been used.
        The do far less damage to the wood being fine wire and give a double fixing instead of one. Unless specified its common practice to use staples to fix the cover and use tacks to fix the Hessian on the bottom .That way it still gives the appearance of being tacked while not doing any damage to the frame.
        There would be far more antiques chairs around using staples instead of tacks.
        Bob
        #499171
        Hollowpoint
          @hollowpoint
          I find it very enjoyable, probably the best program on tv imo. Though it is the only one I watch. 🤣
          I would like to see a bit more technical detail though, even if it was just naming the products being used. Obviously not brand names but chemicals etc.
          #499173
          Nick Clarke 3
            @nickclarke3
            Posted by Hollowpoint on 02/10/2020 19:43:29:
            Nothing to do with model engineering but if you want to extend your viewing I have just seen the last of the BBC documentaries on Dr Harold Shipman. Disturbing, but a superb set of documentaries.
            #499186
            Dave Halford
              @davehalford22513
              leather glue
              It's probably about not giving all your secrets away, some of what you see on Salvage Hunters the Restorers is not the proper way of doing it either.
              #499204
              Sam Stones
                @samstones42903
                And what about the hardly-used S7?
                If the experts like to bring their own tools, I wonder who owns it?
                [Exits left, with sad expression.]
                crying
                #621804
                ega
                  @ega
                  A recent episode is well worth watching – modern (1959) Swiss clock, cold cast artefact and Octopus Student's microscope.
                  PS the Myford is still there!
                  Edited By ega on 19/11/2022 14:48:21
