The Prusa method of p3D-printing holes – who knows more?
Home Forums 3D Printers and 3D Printing The Prusa method of p3D-printing holes – who knows more?
  • #744135
    Versaboss
      @versaboss
      In MEW 342, Roger Froud wrote an article about a device for rotating paint drums. Although I’m not actually interested in that, I skimmed it over because the gadget uses 3D-printed parts. But I was quite surprised about what I found in the last paragraph. Mr. Froud wrote “…the M3 holes use a technique pioneered by Prusa where a hole can be created in an overhanging part. This is done by first printing a slot, followed by a square, then an octagon and finally the circle.”
      Even after reading that several times, I still don’t understand it. Usually, holes are defined in the drawing of the part. As the printing is done layer after layer, I cannot see how these 4 different geometric elements are arranged in the 3-dimensional space.
      I spent the better part of half an hour to find the answer in the Prusa website, but had no success.
      I would be very pleased if someone here can solve that for me (or maybe Mr. Froud is listening here?).
      Kind regards,
      Hans
        Roger can be found on MECH forum, more of his paint mixer in his speedy valve gear thread.
        I suspect it is to do with supporting the layers on the overhanging part. As printed I think the counterbore was below the hole so the slicer software uses those steps to bridge across the counterbore
        #744198
          this should explain it, much as I thought
          #744403
          Versaboss
            @versaboss
            Many thanks Jason, great how you solved that problem. Now I watched that video three times and made some notes. I think that I now understand the most of it.
            I will see (maybe tomorrow) how I can recreate that example in Onshape.
            Kind regards,
            Hans
