Absolute Beginner
I've been going around in circles for a couple of years now. Here are a few personal idle thoughts to open this out a bit more. My opinion ,desire, and final decision, will probably change again next week!
That VMC. Most people who have one seem to be pleased with it and would get it again (though there are a few that would not). I keep coming back to the VMC because it has a knee, a belt drive, and a conventional common motor. There are no gears or electronics board to go wrong further down the line in years to come (but then who's to say they will go wrong!). My engineer Uncle brushed off the height and travel limitation issues with the comment ' there are always ways to get around things'. He does a lot of his work on a Centec, though he does have a bigger mill. Anyway, let's say a 13mm drill bit sticks out of a chuck by 120mm ish. Say you need another 20mm to insert and remove the bit to avoid moving your work in the xy. Say your keyless chuck sticks out 100mm. That's around 240mm of your 345mm taken up. That leaves you 105mm for a vice and/or work piece. If your workpiece is 105mm tall then it could be clamped directly to the table and worked on. If your workpiece is smaller then it can go in the vice. If you are using a 6mm drill bit then you will have another 40mm or more to play with. You could always drill the big stuff in a decent Drill Press, and avoid the height limitations on the VMC. If you were certain you will be working on big stuff all day long, day in day out, then your decision would be easy. You could make a head spacer, which is a simple thing to do. That will overcome many problems and should give you bags of room. End mills and their holders will probably work out around 100mm or more less than the 13mm drill bit and chuck set up, so you will be able to attack most bigger workpieces (100+105mm) without too much trouble and heartache I would have thought. As is always mentioned, your choice of machine will depend on the type of machining you will be doing. As a home machinist/hobbyist you probably have no clea idea what you will be machining further down the line, hence the dilemma of going for rigidity/mass with small daylight, or a lighter machine with bags of daylight. Coupled with the fact that your mill choice has to be fitted within the confines of a meagre sized workplace/shed and you have a nightmare decision to make. If you were buying a machine for paid work purposes then you would have a much better idea of the size you would need; which would keep you from going around in circles so much, and lead you to a firmer decision.
Some guy on another forum (I think it was JS) commented on the fact that you WILL be running out of daylight and travel as you progress in your work. He also commented that the difference in the weight between a VMC and say a RF45 is not enormous. What I got from that comment was that the daylight was more valuable than the mass/rigidity advantage of the VMC. This started me in circles again, as I then started to favour the RF45 type with the greater travel. But then I preferred the belt drive and knee of the VMC. Dizzy or what!
I'm sure if you got a VMC and altered your bench, or if you got the biggest bench mill that you could possible stand on your bench, then you would end up being very pleased with either. If you hit a limitation further down the line then you will overcome it.
Maybe having a get out plan will push you towards a decision. Buy one that you fancy the most and that seems to be the best deal and easiste to get hold of, safe in the thought that you can always sell it on in good condition at a later date for not too much loss (there will be buyers) and move onto a different machine more suitable to your needs at that time. Once you got a machine though, you'll love it and it will be a keeper, despite its limitations.
Steve
