THE MIDLAND – THE ONLY SHOW IN TOWN !
Home Forums The Tea Room THE MIDLAND – THE ONLY SHOW IN TOWN !
Viewing 17 posts - 51 through 67 (of 67 total)
  • #612967
    John Baguley
      @johnbaguley78655
      Our Castings Officer for the N25GA stops in his camper van. He drives into Southam and stops on a car park there that allows overnight camping. All the amenities you could want there.
      It is a bit daft that you can't stop overnight on the field at the exhibition though.
      Rod Renshaw
        @rodrenshaw28584
        I will be going to the show. I have missed them being on over the last few years and feel that the show( s) have to be supported to keep them in being, it somehow feels like a duty to go.
        Similarly, it seems like a good idea to keep supporting the ME suppliers, by buying something from time to time, some of the smaller firms must be feeling fragile with all the pressures and uncertainties at present.
        Rod
        #612978
        Mark Rand
          @markrand96270
          Posted by noel shelley on 10/09/2022 12:39:52:
          I will be on stand 54 running a Brierley drill grinder, this is an industrial machine not a plastic or metal gadget and can handle drills up to 1.25", in parallel, 1, 2 and 3 MT shank
          If I can make it (there is some uncertainty, which will be resolved one way or the other in a week's time), I would like to bring one drill along. Then I/we can see if there's any difference between the Brierley and the relatively simple Meteor ME14 that I picked up a few weeks ago.
          Edited By Mark Rand on 10/09/2022 20:01:13
          #615641
          noel shelley
            @noelshelley55608
            Having been contacted by a member about the show I would like to point out that in the past I have been best know for my small foundry Demos and talks- I will be at the show this year and quite happy to discuss Foundry matters. In case there are any comedians out there who thought about bring a LEFT HAND drill bit – I have a set of cams for left hand form !
            If you are bringing drill bits for sharpening then it would be helpful to mark them ( masking tape ? ) with a name Etc for identification.
            See you there ! Noel.
            #615652
            Grindstone Cowboy
              @grindstonecowboy
              I'll be there, and I'm bringing a vaguely interested friend who, I hope, may become more interested after seeing what's what.
              Oh, got my drill bits too – what's the minimum size you can handle, Noel?
              Rob
              #615654
              DC31k
                @dc31k
                Posted by noel shelley on 01/10/2022 10:28:07:
                Can you do 3 flute left hand core drills?
                A long time ago John Stevenson wrote about mapping the Brierley cam profiles and publishing them somewhere. Do you know if this ever happened or if the information is available form an alternative source? Thanks.
                #615655
                peak4
                  @peak4
                  Posted by DC31k on 01/10/2022 13:28:19:
                  Is this the thread you were remembering?
                  https://uk.rec.models.engineering.narkive.com/GfBbR2uX/brierley-drill-grinder-cams#post18
                  Looks like a candidate for 3D printing for someone cleverer than me.
                  Bill
                  #615677
                  noel shelley
                    @noelshelley55608
                    I got into this with a 4 jaw ZB 10 (I think ) a fairly basic machine and single phase. I then bought an as advertised ZB25,though it had ZB32 on it and only a couple of cams and the standard accesories were missing, this set the ball rolling Then I got hold of a ZB25 with an almost full set of cams(11,12,13,14,missing) and 2 sets of accesories, plus the point splitting attachment. The standard accesories are easy to make. Some machines use a special wheel with 2 grit sizes others use 2 separate wheels,the dish for point thinning, both my 25 and 32 have the left hand threaded flange for the dished wheel missing – one day I will get round to making one. Having bought 2 wheels that were way out of balance, I bought a Jones and Shipman balancer, this showed how far out they were. I complained to the supplier who sent me a 3rd wheel, this no better than the first 2. Only by making a load of extra weights could I set it up to my satisfaction, and it transformed the machine !
                    I have cams 1 – 10 and at £93 +vat each you can see why I bought the 3rd machine ! Having read the link re John Stevenson and cams Etc I found the fellow at Chesters not very helpful, more interested in telling me my machine was obsolete and that they sold new ones ! A CNC lathe or mill might make it easy to copy the cams !
                    Point splitting or 4 facet grinding is not usually done above about 1/2", above this size point thinning is more common to reduce the chisel edge width.
                    DC31K 3 flute taps in left hand yes, according to the book core drills NO. But strangely 4 flute can be done.
                    Rob, The book states 1/8" or 3mm but below about 5mm it becomes fiddely and for what those sizes cost at the show for a box of 10 not worth the time.
                    Mark, the big difference between the brierley and the Meteor will be the time taken to do the job and the fact that by changing the cam a different point can be generated, new they were very expensive but veratile.
                    Look forward to see you at the show ! Noel.
                    #615684
                    Nigel Graham 2
                      @nigelgraham2
                      ZAN
                      Camp-sites.
                      My first full weekend at the show was pricey as the only site I could find was a fairly posh one near Starfford-on-Avon. However, I have found another, and used it for about 3 years running (BC!) ]
                      It is only a few miles from the Show Ground, too: Churchlands Farm, on the fringe of the village of Harbury.
                      Basic, low-cost, no frills – the loos and showers are or were when I last there, in converted shipping containers; and the entrance is slightly disconcertingly through a small industrial estate. Not too far to walk to the pub, either, which I hope has survived The Pestilence.
                      A lot of the other campers, the owner told me, are HS2 builders staying in caravans for the week, going home at weekends. (The route passes near to the village.)
                      Try them: 07904 496940
                      #615685
                      DC31k
                        @dc31k
                        Posted by noel shelley on 01/10/2022 17:34:32:
                        I just spent some time today reading through all the Brierley stuff at lathes.co.uk To my reading, it says the ZB60 and 80 have always been able to do three flute drills. But the early ZB32 could not, ony three flute taps.
                        The later brochures for the ZB32 say it can do 3 and 4 flute drills so Brierley must have added the feature at some point.
                        The later literature also notes that the machines can do 20 point styles. Like you, I have only ever seen cams up to 14, so maybe there are more cams to collect.
                        That is why it would be good to see maps of the cams: you could compare a standard two flute drill to a four flute. The single flute and three flute tap ones would tell you how they managed to work the machine with odd numbers.
                        #615689
                        noel shelley
                          @noelshelley55608
                          DC31K, There are some points where you only use rotary motion, then there's point thinning and point splitting the adman would count these so 20 would be possible. I have 4 and 4A cams as well.
                          As to 3 flute core drills I think the problem is grinding 1 flute without hitting the next ? A smaller wheel and upping the speed with a VFD might do it ?
                          Mapping the cams should be easy, sit it on a rotary table, noting the pin position and a DTI to read height Etc every 5 degrees rotation, or 3.6* to give 100 points ! A job for a cold wet wintery day, do it in front of the fire !
                          Ah well ! Noel
                          Edited By noel shelley on 01/10/2022 20:08:29
                          #615691
                          Mark Rand
                            @markrand96270
                            With the rotary table sat on your knees laugh.
                            #615937
                            Clive India
                              @cliveindia
                              Posted by noel shelley on 01/10/2022 20:06:38:Various Good Hints/Experiences
                              Noel, I found your comments very interesting.
                              I stumbled upon them by accident – I wouldn't normally be attracted by, what is to me, an extremely boring thread.
                              Many other people would see/contribute if it was in its own thread I think. wink
                              #615942
                              not done it yet
                                @notdoneityet
                                Posted by Clive India on 04/10/2022 10:02:38:
                                Agreed.🙂 +1 and all that.  Useful info that will be lost, otherwise.
                                Edited By not done it yet on 04/10/2022 10:18:13
                                #615955
                                noel shelley
                                  @noelshelley55608
                                  Thankyou, Clive and NDIY, I have added a reference to this thread from the BRIERLEY DRILL GRINDER thread I started a while back, and a picture of the often lost V gauge with dimentions. I have not put dimentions for the other tos that go with this machine but if there is interest it can be done. Noel.
                                  Edited By noel shelley on 04/10/2022 12:39:05
                                  #615957
                                  steamdave
                                    @steamdave
                                    This topic seems to have drifted Off Topic lately. Returning to the original theme, if people are becoming less willing to display their models and also attend shows, what do they do with their models once built?
                                    Some of the loco builders can run their engines on a club track, but there are a considerable number who are not club members or are not interested in locos or traction engines. I would think that for them, a Model Engineering show would be an ideal opportunity to showcase their efforts. (Previous reasons for not attending understandable).
                                    The Emerald Isle
                                    #615987
                                    noel shelley
                                      @noelshelley55608
                                      This thread drifted in part due to the Brierley drill grinder I will be operating at the Midland show ! As to models, if you have a detailed and valuable model to transport, one needs a custom box to avoild the model getting damaged. In the case of 2 of my models they are both all I can lift so just loading them into a transport box would be difficult, and once in the box I would be unable to lift it at all ! That I'm not a carpenter just adds to the problem. At least a scratch on the Brierley will not spoil it ! Noel.
