The diesel controversy
Home Forums The Tea Room The diesel controversy
Viewing 25 posts - 26 through 50 (of 204 total)
  • #296193
    Martin 100
      @martin100
      Diesels will always be filthy things, yes even your modern 'Euro 6' things with all their save the planet claims by the manufacturers.
      Long or even 'zero' service intervals on emission control systems mean any exhaust treatment on cars will be severely compromised compared to larger vehicles such as buses and HGV's who have the facility to top up with adblue (for example) on a regular basis.
      So the really big polluters in our towns and cities are diesel cars of all ages and not the fewer but significantly larger vehicles some point their fingers at.
      If you have the time this is one of the original reports on the huge discrepancy between the lab results and the real world and how some manufacturers like BMW are significantly more compliant than others. VW do not coming out smelling of roses. (If this is the one I recall it was the manufacturers are not actually named, but the identity is revealed by engine size data and photos of the test gear in situ)
      Lambton
        @lambton
        Ady1,
        "You can't burn carbon "away" it will always be present
        Carbon has the highest melting point of the elements, and when you melt carbon you are on the way to making a diamond"
        Carbon burns by reacting with oxygen to form the gas CO2 and with nitrogen to form gaseous NOx. in an engine where combustion is always incomplete some carbon will remain as a fine particulate. This particulate and the NOx gases are the main problem with diesel engines. Yes the latest diesels are god but only by the use of additives and periodic burning off of the particulate filter. Both are a question of regular maintenance and will probably suffer as the engine gets older and more worn.
        Diamond burns very easily leaving no residue as it has fully reacted with the oxygen to form CO2.
        I suggest anyone who wants to know more about carbon and its properties to read Stuff Matters by Mark Miodownik.
        #296196
        matt merchant
          @mattmerchant42413
          Posted by Cornish Jack on 03/05/2017 11:54:57:
          Diesel, on the other hand works, as advertised, from the word go
          slight dispute with this statement, as I understand it the DPF system in the majority of modern diesels need to be up to temperature before doing the business otherwise the filter clogs up with gunk blocking the exhaust to the extent of causing back pressure, which in the case of the Peugeot GT I used to own totally destroyed the turbo.
          in relation to the OP its unfortunate I traded it in 6 months ago as a scrappage scheme would have paid more than I accepted part ex, I suspect the trade knew this was coming so were offering below market value.
          the experience of owning that French money pit put me off the whole concept of the 'clean diesel' in general and will never buy a pug again as it cost in repairs what I paid for it originally all in about 18 months
          #296199
          JA
            @ja
            Posted by Lambton on 03/05/2017 13:59:05:
            Carbon cannot burn with Nitrogen to form NOx. Carbon cannot burn with Nitrogen under normal conditions and probably any conditions.
            I am trying to keep away from this thread. It is a bit too close to my working career.
            JA
            Edited By JA on 03/05/2017 14:24:04
            #296200
            Swarf, Mostly!
              @swarfmostly
              Ady1,
              Where's the 'C' in 'NOx'? Just asking!
              Best regards,
              Swarf, Mostly!
              #296207
              Martin 100
                @martin100
                You do not specifically need Carbon to produce NOx, just something like air that contains nitrogen and oxygen. The NOx is only formed because of the combustion temperatures. Warm air up sufficiently by whatever means and you will get NOx. Lower the combustion temperatures and you reduce the NOx. Diesels generally have much higher combustion temperatures and pressures hence more NOx.
                #296208
                Lambton
                  @lambton
                  JA and Swarf,
                  Quite correct – slip of the mind I meant to say nitrogen reacts with oxygen to form NOx
                  #296210
                  richardandtracy
                    @richardandtracy
                    OK.
                    Would those diesels be acceptable if burning waste chip oil in the cities instead? The carbon is coming from renewable resources and there'd be no net emissions.
                    I suspect the answer is 'no'. It's the particulates that are the problem, not the ultimate source of them. I am sure there is a technological solution, but I am not sure it's worth it. This from someone who last year bought a diesel and doesn't want to be banned from using it. The question I'm left thinking is 'Do I care that people in overcrowded, stinky cities are dying prematurely?'. Probably. So what to do?
                    We can be certain that if politicians have any say in the matter, the least rational and most expensive response will be adopted.
                    Richard.
                    #296211
                    Bob Brown 1
                      @bobbrown1
                      It's never as simple as we are told, emissions come from a number of sources of which diesel cars only form a small part, most seem to ignore things like gas/oil central heating. While on the face of it EV may seem to be the way to go but that comes with it's own set of problems not least the electricity supply network and that electricity still needs to be generated. There is concern that the amount of electricity demand could go up by as much as 30% in the next 30 years. The average UK home uses around 4,000 kWh/year but add in a charging system for an EV and it increases considerably, mind you we probably use more than the average home with all our machines.
                      #296213
                      Cornish Jack
                        @cornishjack
                        "Now that is an example of a really closed mind.
                        We need to solve the PM problem not scream "my diesel car is not the problem"."
                        What on earth prompted that Teddy thrown from the pram??
                        This constant (and only relatively recent) wittering on about 'diesel pollution', as distinct from all the other rubbish spilled into the atmosphere, may well have some political convenience (keep the plebs arguing about something, anything) but is very much a child of the moment. I have no particular axe to grind pro-diesel but the realistic alternative IS petrol, NOT electric. Straight amps are almost entirely dependent on wiggly amps and they cause pollution in production. I should, perhaps, point out that I come from an era when a half day in a clean white shirt needed a replacement and when buses had to be guided by a pedestrian!
                        Pollution? – you don't know the half of it!
                        rgds
                        Bill
                        #296217
                        Peter Bell
                          @peterbell11509
                          Interesting subject and also a difficult one really as no matter what what you do it produces pollution and we need transport. We live on a road and the 38t lorries are quieter (road noise and engine) than the average private car and also looking at figures produce less pollution as all seem to comply to Euro6 with Adblue .
                          This report makes interesting reading especially P7 & 10, perhaps someone can comment on it.
                          Peter
                          https://www.gov.uk/government/uploads/system/uploads/attachment_data/file/579200/Emissions_airpollutants_statisticalrelease_2016_final.pdf
                          An extract from it is below.
                          "Most of the emissions from residential, public, commercial combustion in these last 3 years – 79 per cent for both pollutants – are from the use of wood as a domestic fuel"
                          #296232
                          Barnaby Wilde
                            @barnabywilde70941
                            There you go, it's all kicked off on a do they / don't they pollute discussion with facts & figures bandied around like sweeties.
                            The current attack on diesel vehicles has nothing to do with air pollution. It is all down to economics. It is driven by the need to tax & tax heavily to replace dwindling tax revenues from other sources.
                            #296235
                            Vic
                              @vic
                              The Diesel car ban is on its way, it will take a while though. It can’t come soon enough for those that live in built up areas.
                              #296236
                              John Stevenson 1
                                @johnstevenson1
                                Very political though.
                                They can ban diesel cars and force you to move to petrol or hybrid but how about vans and lorries ?
                                There are no petrol vans sold in this country other that possibly a few rare ones and certainly no lorry's.
                                So are these going to be exempt ? if so it makes a farce of it.
                                All it will take is two lorries on every motorway slip road and every road into London, lock them up and go home for the day.
                                Edited By John Stevenson on 03/05/2017 18:57:23
                                #296238
                                Mark Rand
                                  @markrand96270
                                  I think I must agree with Mick's comment above. There do seem to be a few predjuces being viewed on this thread. Just a few points:-
                                  1. Many modern car diesels use urea injection (Adblue) as well as pretty much all commercial diesels. This implies that they have NOx reducing catalyists, which use the ammonia formed by the dissulution of the urea to reduce the NOx to N2 and H2O. Adding extra urea is simple, cheap and isn't needed often. It's no more a maintenance issue than keeping the tyres inflated.
                                  2. All modern road diesel engines have particle filters, which work perfectly well when cold (it's a filter, not a valve). They do need regeneration, by burning off the captured particles. This is done aither with a separate injector into the exhaust or by modifiying the fuel injection timing to increase the exhaust temperature. This process normally takes place when the vehicle is running steadily at 50mph or more and is carried out when the filter back pressure rises beyond the desired amount. Filter and catalyst replacement on a diesel is identical to catalyst replacement on a petrol engined car.
                                  3. Older vehicles with higher pollution get replaced with newer ones with lower pollution, whether they are petrol or diesel powered. There is an issue with freight vehicles, taxis and busses because these often have a longer working life and far higher milage within their life.
                                  4. The current Euro 6 standards for cars are effectively identical for petrol and diesel, with 33% more NOx allowed to the diesels and twice as much CO allowed to the petrols. Euro 7 will almost certainly be identical for both.
                                  Note:- I'm not completely unbiased, I'm very happy with my real 60mpg in mixed motoring and 80mpg in motorway cruising.
                                  Edited By Mark Rand on 03/05/2017 19:06:13
                                  Edited By Mark Rand on 03/05/2017 19:08:36
                                  #296240
                                  Barnaby Wilde
                                    @barnabywilde70941
                                    If you compare our economy to the human body, then diesel is its blood.
                                    Just about the only thing paying tax these days is a PAYE worker. If they drive a diesel car to get to work then that's just bad luck on their part.
                                    They are about to get caught up in one of the only ways our Guv'mnt' can think of to tax those multi-national conglomerates who channel most of their wealth offshore.
                                    They cannot ban diesel, they can only increase the tax on it on the basis that higher costs will reflect in lower mileages.
                                    But it won't will it. All that happens is consumers pay a higher price for their goods & the PAYE worker who commutes in a diesel car gets shafted.
                                    #296241
                                    Stuart Bridger
                                      @stuartbridger82290
                                      20+ years ago, I used to maintain a computer for an organisation that was based on the Euston Road in London. It was on the 3rd floor and the room housing it had no air conditioning. They used to keep the window open 24 x7. How that machine every kept running I don't know. It used to get through tape drives (remember them) at a crazy rate. If you had to pull a PCB (again when computers had more than one), you couldn't even see the chips for the thick layer of sooty dust. It certainly put a new meaning on particulate pollution.
                                      #296243
                                      Barnaby Wilde
                                        @barnabywilde70941
                                        Posted by Stuart Bridger on 03/05/2017 19:35:03:
                                        Yeah. I remember those days.
                                        But the PCB's I used to pull were covered in a mixture of nicotene & cheap carpet tile fluff.
                                        #296249
                                          Phew! More hot air in this thread than come out of my exhaust!
                                          Posted by Russell Eberhardt on 03/05/2017 11:24:38:
                                          One problem seems to be the lack of understanding of the difference between "air pollution" and "greenhouse gas emission".
                                          In general diesel cars produce less CO2 than petrol (except hybrids perhaps) but diesel produces more particulates and NOx. So we have to judge which is more important, the health of our present population, particularly in cities, or the effects of global warming on our grandchildren.
                                          Russell
                                          Probably the most useful post in the above discussion
                                          I went to LPG to reduce my emissions because the higher H:C ratio means less CO2.
                                          Then I went diesel because the greater efficiency meant even lower CO2 (I managed 60mpg on a trip to Devon and back recently, I was lucky to hit 27mpg on LPG).
                                          Now I discover I was suckered into believing the hype around 'clean diesels'.
                                          As one or two people have mentioned, trucks manage not to produce a fraction of the pollutants per gallon of diesel that cars do. This is not because big engines are more efficient, it is because the test the manufacturers have to build them to pass are carried out under real road conditions instead of the totally artificial circumstances car are tested on.
                                          Proper testing of diesel cars in the answer, it will mean they bring in decent particulate filters and adblue – but if they siphon off a fraction of the budget for heated steering wheels and 'apps on your dashboard'…
                                          The real answer is electric, because even if the power is generated from fossil fuel, the emissions will still be lower.
                                          There were more electric cars than IC cars on Victorian roads. As someone asked on the radio, what if the electric car had 120 years of development like the IC car has…
                                          MW
                                            @mw27036
                                            Posted by Neil Wyatt on 03/05/2017 21:26:43:
                                            I think the reply would be "what's the quickest way into your wallet" rather than trying to preserve resources, the Victorians would've thought our world numbers to be absurd and impossible to support, so they wouldn't buy the argument that resources needed to be preserved, precisely because they believed in a future world where similar numbers of them would be around in their day.
                                            Some early electric cars seemed ungainly, the appeal of IC fuels is the high amount of energy they contain that allows them to exceed the horse power of any electric motor. But I don't doubt it is a good idea and definitely very underrated considering what we know now about putting excessive waste gasses into our atmosphere.
                                            You might put it like this, they were driven by their ambition to provide fast transport, and they saw the potential in petrol and knew they could pull it off if they tried hard enough. Every car company was building cars that competed against each other with speed in mind.
                                            Electric cars on the other hand, probably didn't seem like it had potential for that, they didn't have the "goal" that we have now to provide cheap and energy efficiency in their transport. So therefore, without the goal, means no ambition, no ambition means it never happened.
                                            Michael W
                                            Edited By Michael-w on 03/05/2017 21:58:48
                                            #296255
                                            Anonymous
                                              As someone asked on the radio, what if the electric car had 120 years of development like the IC car has..
                                              The electrics are the easy bit, just the back end of a VFD with some fancy software to allow for bidirectional power flow. The main limitation is battery technology. That's one reason the automotive industry is looking at mild hybrids, rather than pure electric. Another reason is that the smaller battery packs are usually around 42V, so below SELV limits. The pure electric vehicles I worked on had battery voltages in the range of 200-400V. I can tell you that from a practical point of view they can be a shocking experience. disgust
                                              #296258
                                              Bob Brown 1
                                                @bobbrown1
                                                What are the safety implications of lithium ion batteries in cars in an accident? fire?
                                                #296261
                                                Clive Hartland
                                                  @clivehartland94829
                                                  No one has mentioned Solar power, I think development will come from that direction but of course driving at night will be a bit of a sod!
                                                  #296266
                                                  Michael Briggs
                                                    @michaelbriggs82422
                                                    The lithium battery pack in a Mercedes C Class 350e hybrid weighs in at about 200 Kg, I wonder how much CO2 was generated making that. It will be interesting to see what happens to such a car when it is a few years old. Regards, Michael
                                                    #296267
                                                    Dod Mole
                                                      @georgeclarihew
                                                      What if the electric car had 120 years of development?
                                                      The electric car has had 110 years of development.
                                                      Quote "" For city work, where smooth and quiet running are of more importance than actual economy of working, the electric vehicle is exceptionally suitable; but its universal adoption is limited by the great weight of the storage cells, and by the necessity of recharging after from 30 to 40 miles of running over average roads in fair condition. If a more compact system of storing electrical energy could be devised, the objections to the electric car for general purposes would disappear; but at the present time none of the many promises has been fulfilled, and there are no indications that the difficulty will soon be solved.""
                                                      Description of power supply of an 8 B.H.P. Electromobile of the London Electromobile Company :- ""the battery consists of forty-five cells, weighing, apart from the case, about 10 cwt. and has a capacity of 135 ampere hours, equivalent to a continous discharge of, say, 27 amperes for five hours. This current, at a pressure of 90 volts, is sufficient to drive the carriage illustrated in fig. 498 for 40 miles under average conditions.""
                                                      It goes on to describe regenerative braking and finishes with :- ""Certain manufacturers are now combining the petrol engine and the electric-motor systems with a view to dispensing with the use of accumulators and change-speed gears while retaining the desirable features of both the systems. Current for the motor is generated by a dynamo driven from the engine, but the combined arrangement has so far only been applied to commercial vehicles of the heavier classes, and its general adoption is as yet a question of future development""
                                                      Copied from Modern Power Generators published by the Gresham Publishing Company MCM VIII
                                                      So what progress has there been in the intervening years?
                                                      Edited By George Clarihew on 03/05/2017 23:16:19
