If my brother gets excess structural steel left over from a job, I am quite happy to use that steel.
I know of someone, recently, that paid a fiver for a metre length of 50mm x 3mm square steel tube. Not stolen!
I cut up an exercise bike recently, for the steel for a cutting and welding job. Should be OK as it was all welded together originally. More than adequate to make the support for a cutting table conversion of the band saw, for vertical operation. I expect I shall retain some round from it, too.
Anyone want the cast wheel? It is about 300mm diameter x 25mm at the rim. Still has a free-wheeling sprocket affixed to it.
I’ve often annealed steel shafts from scrap agricultural machinery – as long as the material machines OK. Stick a piece in the kiln, heated on E7 power and left to cool slowly.
You don’t think that Myford Boy (on you tube) buys in freshly produced aluminium for his casting projects, do you?
I have a stock of bought-in materials as well, of course.
I have machined down socket drive extension bars before now. And lots of other bits, too.
