Hello Paul,
Thanks for your comments about making a case for the clock.
I’m quite impressed that your ideas and description are so aligned with my own. It is however, hard to avoid the neat and clean line concept of a carriage clock.
My ideal, and as you suggest, would be a four sided `glass and brass’ case, with the edges of the glass bevelled to add some prismatic colour. The vertical corners would be of slotted brass, suitably profiled to add further character. Similar in principle to a carriage clock, it would have a hinged front for winding purposes, while the top would be a sheet of brass with a central fretted-brass handle. The escapement needs to be visible, so I think that the top ought to be pierced somehow to let in more light, and preferably allow visual access. I suppose a fifth glass window, suitably bevelled and sealed at the edges, would provide this and some necessary dust protection.
While that would be my ideal, I have to admit that although the clock really deserves a quality case to show it off, we are on a very limited budget. That’s why I’m still looking at a plain acrylic case with mitred edges. Incidentally, I would have thought that WD40 would be a stress-crack agent for acrylic, but obviously you have found it to be OK!?.
On a totally different subject, I designed and manufactured a five-port micro-valve for microscopic research purposes. It featured an acrylic body (polymethyl methacrylate), better known as Perspex. The centre of the valve body was machined out to an accurate diameter of 9.5mm but, because I needed a highly polished finish beside an accurate diameter, I decided to lap the bore with metal polish. What happened during the initial development stages was amazing.
The surface of the hole crazed to a depth of about 2-3mm!
I was generating too much heat during the drilling and boring stages. By reducing to a much lower level the amount of heat being generated and pulling the swarf and lots of cold air through the ML7 headstock mandrel with a vacuum cleaner’s suction, stress cracking was eliminated.
The finishing steps included reaming with a brand new adjustable reamer, `lubricated’ and cooled with clean, slightly wetted water, followed by lapping and polishing. This time, metal polish didn’t introduce the cracking.
By the way, I have occasionally noticed this same stress-cracking effect has introduced crazing to the edges of acrylic security screens, where human body oils and other substances have made contact.
We are getting there, but slowly.
You’ll notice that I’ve added an extra image to my clock pictures. It’s a 3D isometric like the HLR version, but converted to `Solid’.
Sam
