Here are the results from attempting to turn fully hardened silver steel. I used two inserts, in both cases with a 0.4mm radius nose:
1. Koroloy CCMT09T304HMPNC3120 – general purpose positive rake carbide insert for steel
2. Koroloy CCMW09T304 grade KB320 – a CBN insert for steel and cast iron with zero rake
The test bar was 25mm diameter. For both inserts I ran the lathe at 1200rpm (about 100m/min), with a feedrate of 0.1mm/rev and a depth of cut of 0.2mm. In both cases the finish was very good and the swarf came off bright orange. After use the carbide insert showed definite signs of distress on the cutting edge, whereas the BCN insert didn't look like it had been used. Under the magnifying glass the carbide finish looked fairly uniform, but not perfect. The CBN insert finish looked completely uniform; results borne out by the surface roughness measurements. These were (Ra in µm):
Carbide: 1.03 0.85 1.35 Average = 1.08
CBN: 1.51 1.44 1.45 Average = 1.47
The swarf came off as a complete tangle of very fine ribbons, just like a very fine metal pan scourer. I've never seen swarf like it; very fine, but completely uniform, and quite brittle. Here's a picture of the swarf and test bar, the CBN turned end is on the right:
Using my hardness file set I estimate that the end turned by the carbide insert is about 55Rc, ie, it has lost a little hardness. For the CBN end the hardness seems to have gone up (!), as now the black file, 65Rc, will not touch the surface; I wasn't expecting that. It makes some sort of sense though; the whole point of 'hard turning' is to replace cylindrical grinding as the finishing process. If the work ends up softer afterwards it rather defeats the object of the exercise.
As I understand the theory the idea of hard turning the idea is that at the cutting edge the metal is well above red heat, and so is soft. While in theory, again, most of the heat is supposed to come out with the swarf I don't quite see how the surface of the parent metal stays hard, as what quenches it? May be the key is the fact that the CBN insert has zero rake?
Well, that has been a most interesting experiment. The CBN insert certainly lived up to expectations, producing a superb finish without affecting the hardness. Mind you at £25 for a single edge non-regrindable insert it damn well ought to!
