After a bit of a break, I've done another set of trials; this time on silver steel. The silver steel used was 25mm diameter, recently bought in my local professional tool warehouse. There's no direct equivalent in Machinery's Handbook, but I think that the tool steel W1 is a fairly close match; W1 is a high carbon plain steel for water hardening. For W1 the recommended speeds are 100fpm for HSS and 350fpm for uncoated carbide. For these trials I used speeds of 370rpm and 1200rpm. The insert used was a 0.2mm radius insert from Korloy, grade NC3120 for steel. In view of the small nose radius in each case depth of cut was 20 thou and a feed rate of 2 thou/rev. I tried four combinations:
Trial1: 370rpm, no coolant
Trial2: 1200rpm, no coolant
Trial3: 370 rpm, coolant
Trial4: 1200rpm, coolant
General Appearance:
Trial1: Uniform finish but felt slightly rough
Trial2: Uniform finish, feels smooth
Trial3: Uniform finish, feels smooth, but there was concentric banding every 40 thou
Trial4: Uniform finish, feels smooth, but there was concentric banding every 40 thou
Under a Magnifying Glass:
Trial1: Surface is slightly torn
Trial2: Smooth and even finish
Trial3: Smooth and even finish, but with banding
Trial4: Smooth and even finish, but with banding
Swarf:
Generally the swarf came off in long curls. Without coolant the curls were very tight, and at 1200rpm were dark blue in colour. With coolant the curls were much more open.
Surface Roughness (Ra µm):
Trial1: 2.67 2.51 1.80 Average=2.33
Trial2: 1.80 1.75 1.81 Average=1.79
Trial3: 1.63 1.76 1.63 Average=1.67
Trial4: 1.45 1.63 1.50 Average=1.53
Just out of interest I also tried a run at 1200rpm with no coolant and a feedrate of 1 thou/rev. The finish felt very smooth and even, the average roughness was 1.65µm. Slightly worse than with 2 thou/rev, so might as well use the higher feedrate and save time. I was slightly surprised that with such a low feedrate the swarf still came off in long curls.
Generally the finish from any of the trials was acceptable, with a slight caveat for Trial 1. I was rather surprised by this, as I started the trials with the memory that silver steel was a bit of a PITA to machine and was prone to tear if the cutting conditions were wrong. Either my memory is playing tricks, or I had a duff batch of silver steel. In practice I think I'll use about 350fpm with no coolant. Although the finish is slightly rougher it is acceptable and doesn't have the very visible banding. I've no idea why the coolant should cause the banding, but it was consistent.
In the near future I need to do a batch of hardening in the electric furnace. When I do I'll put a length of the silver steel in and harden it. I'll then have a go at turning it in it's hardened state.
Edited By Andrew Johnston on 21/05/2012 21:59:44
